we're doing a project for school with our Arduino Esplora and try to visualate the axis in Processing based on a cube.
It's not our code and we don't know so much about programming with Processing, so we really need your help.
If we run the program, the "cube" won't move. We think the program can't read the axis and it's just a failure in the code.
Here's the processing code:
* ADXL345 Library Examples- pitch_roll.pde *
* Copyright (C) 2012 Anil Motilal Mahtani Mirchandani(anil.mmm@gmail.com) *
* License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> *
* This is free software: you are free to change and redistribute it. *
* There is NO WARRANTY, to the extent permitted by law. *
// If you are working with Arduino Mega
// sudo ln -s /dev/ttyACM0 /dev/ttyS8
import processing.serial.*;
Serial fd;
int pitch = 0;
int roll = 0;
int yaw = 0;
void setup ()
size(640, 360, P3D);
//Connect to the corresponding serial port
fd = new Serial(this, "COM6", 9600);
// Defer callback until new line
fd.bufferUntil('\n');
void draw ()
//Set background
background(0.5);
pushMatrix();
translate(width/2, height/2, -30);
//Rotate
rotateX(((float)pitch)*PI/180.0);
rotateZ(((float)roll)*PI/180.0);
rotateY(((float)yaw)*PI/180.0);
//Print data
print("Pitch: ");
print(pitch);
print(", Roll: ");
println(roll);
print("Yaw: ");
println(yaw);
scale(90);
beginShape(QUADS);
fill(0, 255, 0); vertex(-1, 1, 1);
fill(0, 255, 0); vertex( 1, 1, 1);
fill(0, 255, 0); vertex( 1, -1, 1);
fill(0, 255, 0); vertex(-1, -1, 1);
fill(0, 255, 255); vertex( 1, 1, 1);
fill(0, 255, 255); vertex( 1, 1, -1);
fill(0, 255, 255); vertex( 1, -1, -1);
fill(0, 255, 255); vertex( 1, -1, 1);
fill(255, 0, 255); vertex( 1, 1, -1);
fill(255, 0, 255); vertex(-1, 1, -1);
fill(255, 0, 255); vertex(-1, -1, -1);
fill(255, 0, 255); vertex( 1, -1, -1);
fill(255, 255, 0); vertex(-1, 1, -1);
fill(255, 255, 0); vertex(-1, 1, 1);
fill(255, 255, 0); vertex(-1, -1, 1);
fill(255, 255, 0); vertex(-1, -1, -1);
fill(255, 0, 0); vertex(-1, 1, -1);
fill(255, 0, 0); vertex( 1, 1, -1);
fill(255, 0, 0); vertex( 1, 1, 1);
fill(255, 0, 0); vertex(-1, 1, 1);
fill(0, 0, 255); vertex(-1, -1, -1);
fill(0, 0, 255); vertex( 1, -1, -1);
fill(0, 0, 255); vertex( 1, -1, 1);
fill(0, 0, 255); vertex(-1, -1, 1);
endShape();
popMatrix();
void serialEvent (Serial fd)
// get the ASCII string:
String rpstr = fd.readStringUntil('\n');
if (rpstr != null) {
String[] list = split(rpstr, ':');
pitch = ((int)float(list[0]));
roll = ((int)float(list[1]));
yaw = ((int)float(list[2]));
and our Arduino code to only read and print the axis and temperature:
Verschiedene Temperaturen messen und via LED ausgeben
#include <Esplora.h>
Serial.begin(9600); // Initialisiere Kommunikation mit Computer
// Temperatur einlesen
int celsius = Esplora.readTemperature(DEGREES_C);
// Temperatur ausgeben
Serial.print("Temperatur betraegt ");
Serial.print(celsius);
Serial.println(" Grad Celsius");
Serial.println("");
// 0 Grad und weniger: Blaue LED
if (celsius <= 0)
{ Esplora.writeRGB (0,0,205); }
// Zwischen 0 und 21 Grad: Lila LED
if (celsius >= 21)
{ Esplora.writeRGB (255,0,0); }
// Ab 21 Grad: Rote LED
{ Esplora.writeRGB (153,50,204); }
// Achsen erkennen
int xAxis = Esplora.readAccelerometer(X_AXIS); // X-Achse einlesen
int yAxis = Esplora.readAccelerometer(Y_AXIS); // Y-Achse einlesen
int zAxis = Esplora.readAccelerometer(Z_AXIS); // Z-Achse einlesen
//Achsen ausgeben
Serial.print("x: ");
Serial.print(xAxis);
Serial.print("\ty: ");
Serial.print(yAxis);
Serial.print("\tz: ");
Serial.println(zAxis);
Serial.println("");
Sorry for the german comments.
Hope you can help us.
Your sincerely,
Josh6796
