arduino ethernet auto post need HELP!!
Hi! i use arduino ethernet and real time module DS3231.
i need send request to server every 60s. but not working:s i use in ethernet web server
code:
#include <SPI.h>
#include <Ethernet.h>
#include <DS3231.h>
#include <Wire.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
IPAddress ip(192,168,1,177);
DS3231 Clock;
bool Century=false;
bool h12;
bool PM;
byte ADay, AHour, AMinute, ASecond, ABits;
bool ADy, A12h, Apm;
int siurblys = 0, i = 0;
String readString = String(30), readString1;
double tempC = 0, dregn = 0;
int yourarduinodata = 999;
String yourdatacolumn = "yourdata=";
String yourdata;
EthernetServer server(80);
  Wire.begin();
  Clock.setSecond(1);
  Ethernet.begin(mac, ip);
  server.begin();
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        readString += c;
        Serial.write(c);
        if (c == '\n' && currentLineIsBlank) {
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
	  client.println();
          ProcessCheckbox(client);
          test();
          client.println("grab({");
          client.println("\"temperatura\":");
          client.println(temp());
          client.println(",\"dregnumas\":");
          client.println(dreg());
          client.println(",\"siurblys\":");
          client.println(siurblys);
          client.println("})");
          readString = "";
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    delay(1);
    client.stop();
    Serial.println("client disonnected");
  ReadDS3231();
void ReadDS3231(){
  int second;
  second=Clock.getSecond();
  if(second == 0){
      Serial.println("Issiusta");
    EthernetClient client;
    client.println("GET /search?q=arduino HTTP/1.1");
    client.println("Host:192.168.1.103");
    client.println();
i send data in ReadDS3231 method time forks fine but but data not send:s
You left some stuff out:
          test();
So, I will to. Here’s what you need to do:
Besides the stuff PaulS mentioned, there is this:
    client.println();
Where are you connecting to the server? You need something like this:
IPAddress server(192,168,1,2);
if(client.connect(server,80)) {
    client.println("Host: 192.168.1.177");
    client.println();
   while(client.connected()) {
      while(client.available()) {
         Serial.write(client.read());
   client.stop();
Not working:s
