Arduino ethernet board and Pachube
I'm using an Ethernet Arduino board.
I've downloaded a code that uses the ERxPachube library to upload data to Pachube.
In this code, I didn't use DHCP, I assign the IP address manualy.
It works but at some point, the connection is lost.
Any information about it wiuld be usefull for me.
Chris
You're going to have to post some code. What have you tried already?
Here is the code I use :
Pachube Data Out
Demonstrates use of the ERxPachube library.
Push local sensor data to Pachube server.
If you don't have a Pachube account, register one first (http://www.pachube.com/).
To run this sketch, you need:
  1. Create a same feed as http://www.pachube.com/feeds/23408
    (A manual feed with three data streams with ids 0, 1, 2.)
  2. Use your API key to replace the space holer PACHUBE_API_KEY below.
  3. Use your feed id to replace the space holer feed id 23408 below.
Circuit:
#include <Arduino.h>
#include <HardwareSerial.h>
#include <ERxPachube.h>
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = { 0xCC, 0xBC, 0xBE, 0xEF, 0xAE, 0x91 }; // POD-1 make sure this is unique on your network
// byte mac[] = { 0xCC, 0xAC, 0xBE, 0xEF, 0xFE, 0x91 }; // POD-2 make sure this is unique on your network
byte ip[] = { 192, 168, 0, 71}; // LUTETIUM : POD-1 no DHCP so we set our own IP address
// byte ip[] = { 192, 168, 0, 11}; // SODIUM : POD-1 no DHCP so we set our own IP address
// byte ip[] = { 192, 168, 0, 31}; // GALLIUM : POD-2 no DHCP so we set our own IP address
#define PACHUBE_API_KEY "tFWNG4AjZnsefakP70ceeYgCc1A7CYDpFWmznTqe4beEcgYsKq21WkSQ_ipnFzKD_q0fXi-uM4Cj1Px9eG-bEQNik23rEapDxHjXEhOtiiPFKbR980vNWEwnSSkDeCF4" // fill in your API key PACHUBE_API_KEY
#define PACHUBE_FEED_ID 45832 // POD-1 feed id
// #define PACHUBE_FEED_ID 45831 // POD-2 feed id
ERxPachubeDataOut dataout(PACHUBE_API_KEY, PACHUBE_FEED_ID);
void PrintDataStream(const ERxPachube& pachube);
Ethernet.begin(mac, ip);
dataout.addData(0);
dataout.addData(1);
dataout.addData(2);
dataout.addData(3);
// Assign LED to blink once data are sent to Pachube
// pinMode(13, OUTPUT);
Serial.println("+++++++++++++++++++++++++++++++++++++++++++++++++");
// float fSensorData = 15.23; // POD-2
float fSensorData = 55.84; // POD-1
float sensorReading = analogRead(A0); // POD-1 & POD-2
sensorReading = sensorReading * 5 * 100. / 1024.;
// dataout.updateData(0, analogRead(0)); // Example
dataout.updateData(0, sensorReading);
dataout.updateData(1, fSensorData); // POD-1 & POD-2
dataout.updateData(2, "POD-1");
// dataout.updateData(2, "POD-2");
// sensorReading = analogRead(A1); // POD-2
// sensorReading = (sensorReading * 5. / 1024.) * 60. + 800.; // POD-2
// dataout.updateData(3, sensorReading); // POD-2
dataout.updateData(3, analogRead(1)); // POD-1
int status = dataout.updatePachube();
Serial.print("sync status code <OK == 200> => ");
Serial.println(status);
PrintDataStream(dataout);
// Blink the LED
// digitalWrite(13, HIGH);
// delay(1000);
// digitalWrite(13, LOW);
// delay(1000);
delay(10000);
unsigned int count = pachube.countDatastreams();
Serial.print("data count=> ");
Serial.println(count);
Serial.println(",");
for(unsigned int i = 0; i < count; i++)
Serial.print(pachube.getIdByIndex(i));
Serial.print(",");
Serial.print(pachube.getValueByIndex(i));
