Arduino Ethernet board and Relay Shield V2 for servo control
Hi
I am using the Arduino Ethernet Board with the Relay Shield V2 to control the servo payload release.
The servo open and close will be controlled by a software. So when I press the "Open" button, it should open and release the payload and when I press "Close", the servo shaft will close.
I have received some codes but want to put in the codes for the servo movement too
In addition, How do I make the connection from the servo to the Relay Shield
I have attached the code...As of now, the led on the relay will turn on and off. How do I make it control the servo.
#include "Define.h"
#include "Mavlink.h"
  /*---------------------------------------------------------Read UDP MSG---------------------------------------------------------*/
  byte packetBuffer[UDP_TX_PACKET_MAX_SIZE];  //buffer to hold incoming packet,
  int packetSize = Udp.parsePacket();   // if there's data available, read a packet
  // read the packet into packetBufffer
  Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
  mavlink_status_t mavlink_status{};
  mavlink_message_t mavlink_msg{};
  for (int i = 0; i < packetSize; i++) {
    if (mavlink_decode(packetBuffer[i], &mavlink_msg, &mavlink_status)) {
      handle_message(&mavlink_msg);
  delay(10);
  loopcount++;
  if (loopcount % 100 == 0) {
    char ReplyBuffer[UDP_TX_PACKET_MAX_SIZE];       // a string to send back
    int RAWReading = analogRead(0);
    float ADCReading = RAWReading / 1024.000 * 5.000;
    dtostrf (ADCReading, 5, 2, ReplyBuffer);
    // send a reply to the IP address and port that sent us the packet we received
    //    Udp.beginPacket(Remote_ip, Remote_port);
    //    Udp.write(ReplyBuffer);
    //    Udp.endPacket();
  if (loopcount % 10 == 0)
    send_heartbeat();
void handle_message(mavlink_message_t *msg)
  switch (msg->msgid) {
    case MAVLINK_MSG_ID_COMMAND_LONG:
      handle_message_command_long(msg);
    default:
void handle_message_command_long(mavlink_message_t *msg)
  /* command */
  mavlink_command_long_t cmd_mavlink;
  mavlink_msg_command_long_decode(msg, &cmd_mavlink);
  switch (cmd_mavlink.command) {
    case VEHICLE_CMD_PAYLOAD_CONTROL_DISCRETE:
      if (cmd_mavlink.param1 + 0.5 < 1 )
        /*do nothing here*/
      else if (cmd_mavlink.param1 + 0.5 < 2)
        send_long_command();
      if (cmd_mavlink.param2 + 0.5 < 1 )
        /*do nothing here*/
      else if (cmd_mavlink.param2 + 0.5 < 2)
        digitalWrite(RELAY, HIGH);
        char text_msg[50] = "Relay Turn ON!";
        send_text(MAV_SEVERITY_CRITICAL, text_msg);
      else if (cmd_mavlink.param2 + 0.5 < 3)
        digitalWrite(RELAY, LOW);
        char text_msg[50] = "Relay Turn OFF!";
    case VEHICLE_CMD_NAV_LAND:
    default:
void send_heartbeat()
  mavlink_heartbeat_t msg;
  msg.base_mode = 0;
  msg.custom_mode = 0;
  msg.type = 0;
  msg.autopilot = 12;
  msg.mavlink_version = 3;
  msg.rc_status = 0;
  send_message(MAVLINK_MSG_ID_HEARTBEAT, &msg, LOCAL_SYS_ID, LOCAL_COMP_ID, GCS_ip, GCS_port);
void send_text(severity_t severity, const char *text_msg)
  __mavlink_statustext_t msg;
  strcpy(msg.text, text_msg);
  send_message(MAVLINK_MSG_ID_STATUSTEXT, &msg, LOCAL_SYS_ID, LOCAL_COMP_ID, GCS_ip, GCS_port);
void send_long_command()
  mavlink_command_long_t command_long;
  command_long.command = VEHICLE_CMD_OVERRIDE_GOTO;
  command_long.target_system = 1;
  command_long.target_component = 50;
  command_long.confirmation = 0;
  send_message(MAVLINK_MSG_ID_COMMAND_LONG, &command_long, 255, 0, Remote_ip, Remote_port);
I believe the servo part need to be added here
Moderators pls remove this post
I figured it out
