Arduino Ethernet board and Telnet
I've been trying to talk to an Arduino Ethernet board (not shield)
with telnet, and have go nowhere; thanks to this forum I've got
ping running, but the telnet or udp or web stuff I want to add
simply hangs. Below is the sketch I've been trying - it runs ok
(without handling telnet) until the EthernetClient line is added,
and then it hangs - no response to ping, nothing on the serial port.
I'm using arduino-1.0.1 and avr-gcc-4.5.3 (on Linux). It looks as
if the Ethernet library is blocking somewhere, but following through
a maze of C++ class initialisations isn't easy. Can anyone see
where I might be going wrong, or suggest a working library?
Thanks - Will
// Test of Arduino Telnet.
#include <SPI.h>
#include <Ethernet.h>
// Undefine this to get a working program.
#undef TELNET
// the media access control (ethernet hardware) address for the Arduino:
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x92, 0x34 };
// the IP address for the Arduino:
byte ip[] = { 192, 168, 1, 20 };
// telnet defaults to port 23
EthernetServer server(23);
  // Initialise the serial device.
  delay(2000);
  Serial.println("setup()");
  // Initialize the ethernet device
  Ethernet.begin(mac, ip);
  // start listening for clients
  server.begin();
  Serial.println("loop()");
  // Uncommenting this statement hangs the sketch.
  // The response from ICMP is "Destination Host Unreachable"
  // Read bytes from the incoming client and write them back
  // to any clients connected to the server.
#ifdef TELNET
  if (client) {
    char c = client.read();
    server.write(c);
#endif
// eof
please modify your post, select the code and press the # butto to get it proper tagged , makes it easier to read.
seen this thread on the old forum - http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1278686415 - ?
