I have a receipt printer hooked up to my Arduino with the ethernet shield (wiznet one), and the Arduino basically takes POST data from a form, and spits it out onto a thermal receipt. The problem that I’m having is that the first time after a reset or upload, it initializes and gets an IP, but if I try and send anything over, it just times out. If I hit stop in the browser and send again, it’ll sometimes go through this second time, or maybe I have to hit stop and send again, and it works on the 3rd time. Also, if I let it sit for a while, then try to send another bit of data, I have to repeat the process.
How can I get it to work the first time through?
I have the following code:
#include <SoftwareSerial.h>
#include <Ethernet.h>
SoftwareSerial printer(2, 3); // RX, TX
byte mac[] = {
0x54, 0x55, 0x58, 0x10, 0x00, 0x24 };
EthernetServer server(80);
String postString;
String message;
String poster;
printer.begin(9600);
printer.println("---------------PRINTER INIT-----------------"); //Prints this line to the receipt printer
printer.write(0x0A); //Printer End Page
if (Ethernet.begin(mac) == 0) {
printer.println("Failed to configure Ethernet using DHCP");
for(;;)
}else{
printer.println("DHCP Ready");
for (byte thisByte = 0; thisByte < 4; thisByte++) {
// print the value of each byte of the IP address to the receipt printer
printer.print(Ethernet.localIP()[thisByte], DEC);
printer.print(".");
printer.println();
server.begin();
// listen for incoming clients
if (client) {
boolean currentLineIsBlank = true;
boolean hasPOSTdata = false;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (c == '\n' && currentLineIsBlank) {
printer.println("-------------MESSAGE START---------------");
hasPOSTdata = true;
} else if (c == '\n' && hasPOSTdata == false) {
// you're starting a new line
} else if(c == '\n' && hasPOSTdata == true){
}else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
if(hasPOSTdata == true){
postString = postString + c; //append the character to the message string
}else{
postString.replace("+"," "); //translates the + in the data to a space
postString.replace("%2C",","); //translates a comma code to a comma
postString.replace("%27","'"); //translates a parens code to a parenthesis
postString.replace("-"," "); //translates a dash to a space
//form that is posting here submits 2 vars: m=[the message] and b=[the poster]
message = postString.substring(2, postString.indexOf("&b="));
poster = postString.substring(postString.indexOf("&b=")+3);
printer.print("Message:");
printer.println(message);
printer.print("Poster:");
printer.println(poster);
postString = "";
printer.println("");
printer.println("---------------END POST-----------------");
//spit out a quick OK message to tell the client we got the form data
client.println("Content-Type: text/html");
client.println("Connnection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html><head></head><body>OK DONE</body></html>");
client.stop();
i=0;
delay(1);
