Hello,
Since yesterday I've got some problems with my Arduino Ethernet. I hope somebody can point me to some new direction about what to try or can tell me when there is no hope for this instance anymore. I made a brief summary of what I already tried, if there are any gaps, I'd happy to fill them in.
Synopsis:
- Arduino Ethernet runs 24x7 since February 2012 with minor downtimes (e.g. some minor patches of the sketch). Attached to it was a one-wire-bus and a xbee connected via SoftwareSerial (i.e. not on rx/tx), network connectivity was regulary used to push data.
- Arduino Ethernet connected via Usb2Serial Light on a Windows 8 64bit system
- After trying to upload an updated sketch it fails with:
"ser_send(): write error: sorry no info avail"
- Futher attempts to upload this sketch and a simpler one (e.g. Blink) lead to the following error message:
"avrdude: stk500_getsync(): not in sync: resp=0x00"
- Starting the board simply results in a glowing Power LED and the L9 LED, Reset button has no visible effect
Attempts to save "something":
- Tried uploading from a different system (WinXP, 32bit) -> same
- Tried the loopback test http://arduino.cc/forum/index.php/topic,73748.0.html -> successfull
- Read a lot of stuff about 0x00 and ...
- Tried to flash the bootloader with a working Arduino UNO as described here: http://arduino.cc/en/Tutorial/ArduinoISP
C:\Dev\Env\Arduino\arduino-1.0.3\hardware/tools/avr/bin/avrdude -CC:\Dev\Env\Arduino\arduino-1.0.3\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM7 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xde:m -Ulfuse:w:0xff:m
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Dev\Env\Arduino\arduino-1.0.3\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM7
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82] [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98] [20]
avrdude: Recv: . [00]
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
avrdude: Send: A [41] . [84] [20]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00] [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00] [20]
avrdude: Send: P [50] [20]
avrdude: Recv:
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: Send: Q [51] [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
avrdude done. Thank you.
- Since this didn't work, I tried to flash the bootloader with Optiloader like this: http://scuola.arduino.cc/en/content/upgrade-arduino-ethernet-bootloader-latest-version. Sadly this only led to the message
"Target power on! ...No RESET pullup detected! - no target?"
and stopped.
Any idea what I could try besides this? Is there anything deducible what might have caused this?
Thank you very much in advance.
Kind Regards,
Thorsten
