Arduino ethernet Http Request Stops after a while
Hello everyone i have a Arduino Mega it goes to a web server and gets task every ten seconds, it works fine but after half an hour or 45 minutes it says
Connecting…
Connected.
and stops.
Here is what i think; it works like thousand times so code seems fine but maybe there are some problems with buffers or temperature. Thanks for your help
Code is as follows:
String httpRequest(char* server, char* path){
  tmpTaskList = "-";
  TaskList = "-";
  TaskFlag=0;
  Serial.println("connecting...");
  client.stop();
  if (client.connect(server, 80)) {
    Serial.println("connected");
    client.print("GET ");
    client.print(path);
    client.println(" HTTP/1.1");
    client.print("Host: ");
    client.println(server);
    client.println("Connection: close");
    client.println();
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  while (client.available() || client.connected()){
          if (client.available()){
                  char c = client.read();
                  tmpTaskList += String(c);
          if (!client.available() && !client.connected()){
                 for (int i=0;i < tmpTaskList.length();i++){
                          if(TaskFlag == 0){
                                 if(String(tmpTaskList[i]) == "#"){
                                         TaskFlag = 1;
                         }else if(TaskFlag==1){
                                 if(String(tmpTaskList[i]) != "#"){
                                         TaskList += String(tmpTaskList[i]);
                                 }else {
                                         TaskFlag = 2;
           return TaskList;
Or, the String class is fragmenting memory to the point where the Arduino can no longer function. Stop using that class.
what do you suggest i use instead
Post your entire sketch.
C-style strings - NULL terminated array of chars.
