arduino ethernet like server and javascript
anyone know if I can work with js code on the arduino ethernet like server?
thanks
EJTR: anyone know if I can work with js code on the arduino ethernet like server?
thanks
Yep, go and look at these tutorials for the whole APEX thing....
What do you mean "ethernet like"?
sorry if my english is not good , I am learning.
thanks JimboZA for help me . I attach the code for anyone have the same question . It code works good and you need write just numbers not letters.
arduino ethernet—html5—mac—ip—
#include "SPI.h"
#include "Dhcp.h"
#include "Dns.h"
#include "Ethernet.h"
#include "EthernetClient.h"
#include "EthernetServer.h"
#include "EthernetUdp.h"
#include "util.h"
byte mac[] = {0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX};
IPAddress ip(192,168,1,XX);
EthernetServer server(80);
	pinMode(9,OUTPUT);
	digitalWrite(9,0);
	Serial.println("**********************");
	Serial.println("puerto serial iniciado");
	Ethernet.begin(mac,ip);
	server.begin();
	Serial.print("ip server: ");
	Serial.println(Ethernet.localIP());
	if(client){
		Serial.println("new client");
		boolean currentLineIsBlank = true;
		while(client.connected()){
			if(client.available()){
				char c = client.read();
				if(c == '\n' && currentLineIsBlank){
					client.println("<!doctype html>");
					client.println("<html>");
					client.println("<head>");
					client.println("<title>Arduino Server</title>");
					client.println("<script type='text/javascript'>");
					client.println("function validardato(){");
					client.println("var verificar = true;");
					client.println("var dato = /^[0-9-,-.]*$/;");
					client.println("if(!dato.exec(document.frm_test.num_txt.value)){");
					client.println("alert('Campo no valido');");
					client.println("verificar = false;");
					client.println("}");
					client.println("if(verificar == true){");
					client.println("alert('Campo valido');");
					client.println("window.onload = function(){");
					client.println("document.frm_test.num_but.onclick=validardato;");
					client.println("</script>");
					client.println("</head>");
					client.println("<body>");
					client.println("<center><h1>Arduino Ethernet</h1></center>");
					client.println("<center>");
					client.println("<form name='frm_test'>");
					client.println("<input type='text' name='num_txt'>");
					client.println("<input type='button' name='num_but' value='Ingresar Dato'>");
					client.println("</form>");
					client.println("</center>");
					client.println("</body>");
					client.println("</html>");
				 if(c == '\n'){
				}else if(c != '\r'){
				    currentLineIsBlank = false;
	delay(1);
	client.stop();
	Serial.println("cleinte desconectado");
In case you might be interested in a more sophisticated solution: http://forum.arduino.cc/index.php?PHPSESSID=allvae0vt0f3j4pdleb8mscpl6&topic=203450.0 but only for MEGA. HTH, eca
