arduino ethernet shield char manipulation/parsing
hello!
I'm doing GET request on a website with the ethernet shield and I'm having difficulties parsing the result..
the only way I'm getting interesting result is with this bit of code in arduino :
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c= client.read();
Serial.print(c);
serial output :
connecting...
connected
HTTP/1.1 200 OK
Date: Thu, 27 Nov 2014 15:29:18 GMT
Server: Apache
Connection: close
Transfer-Encoding: chunked
Content-Type: text/html
7
-1062-
0
disconnecting.
I'm trying to isoalte the '1062' and trimming the rest to be able to use that number in 'int' format...
I tried converting the char to string to use the String indexOf() but no luck :frowning:
any ideas anyone ? :wink:
thanks in advance!
One way is to capture what is sent back to the client, then use various methods to extract the desired data. The textFinder application might also be of use.
//zoomkat 11-04-13
//simple client test
//for use with IDE 1.0.1
//with DNS, DHCP, and Host
//open serial monitor and send an e to test client GET
//for use with W5100 based ethernet shields
//remove SD card if inserted
//data from myIP server captured in readString
#include <SPI.h>
#include <Ethernet.h>
String readString;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
char serverName[] = "checkip.dyndns.com"; // myIP server test web page server
EthernetClient client;
void setup(){
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    while(true);
  Serial.println("client readString test 11/04/13"); // so I can keep track of what is loaded
  Serial.println("Send an e in serial monitor to test"); // what to do to test
void loop(){
  // check for serial input
  if (Serial.available() > 0) //if something in serial buffer
    byte inChar; // sets inChar as a byte
    inChar = Serial.read(); //gets byte from buffer
    if(inChar == 'e') // checks to see byte is an e
      sendGET(); // call sendGET function below when byte is an e
void sendGET() //client function to send/receive GET request data.
  if (client.connect(serverName, 80)) {  //starts client connection, checks for connection
    Serial.println("connected");
    client.println("GET / HTTP/1.1"); //download text
    client.println("Host: checkip.dyndns.com");
    client.println("Connection: close");  //close 1.1 persistent connection
    client.println(); //end of get request
  else {
    Serial.println("connection failed"); //error message if no client connect
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    readString += c; //places captured byte in readString
  //Serial.println();
  client.stop(); //stop client
  Serial.println("client disconnected.");
  Serial.println("Data from server captured in readString:");
  Serial.print(readString); //prints readString to serial monitor
  Serial.println("End of readString");
  Serial.println("==================");
  readString=""; //clear readString variable
Hey zoomkat!!
thanks for your reply!
I'm trying to make it work but I'm not there yet :frowning:
the output seems to be a series of char still so I can't use the function for the string messages.. There might be another way but I'm a beginner in that domain ;)..
let me know if I'm missing something.. I tried this code but I get an error "invalid conversion from 'char' to 'const char'...
any ideas ??
the ouput of the code you gave me is the exact same one as in my previous message..
cheers
Phil
//zoomkat 11-04-13
#include <SPI.h>
String readString;
char serverName[] = "www.mywebsite.com"; // myIP server test web page server
void setup(){
    while(true);
void loop(){
    client.println("GET /fb.php HTTP/1.1"); //download text
    client.println("Host: www.mywebsite.com");
  else {
    String stringOne = c;
    int firstClosingBracket = stringOne.indexOf('-');
  //Serial.println();
  Serial.print(firstClosingBracket); //prints readString to serial monitor
[/code
A string IS a NULL terminated array of chars. A String is a piece of shit that you don't need. Which are YOU talking about?
hey Paul
ok I didn't know that..
all I'm trying to do is to isolate the number '1062' from the wepage output.
I was trying to use String indexOf() to parse the message until the delimiter '-' but I get an error saying it's an invalid conversion between a char and a string in the serial window..
I'm a bit lost then... any idea how I can parse this message ?
thanks
I modified the code you were trying (below). The www.mywebsite.com seems to be bogus, but the below code parses out 8859 from what is returned, and may work for your server based on the return you posted.
//zoomkat 11-28-14
#include <SPI.h>
String readString;
String data;
int start;
int ind1; // - locations
int ind2;
void setup(){
    while(true);
void loop(){
  else {
    //String stringOne = c;
    //int firstClosingBracket = stringOne.indexOf('-');
  //Serial.println();
  //parse readString for data
  start = readString.indexOf("ml");  //finds a unique start location
  ind1 = readString.indexOf('-', start+2);  //finds location of first -
  ind2 = readString.indexOf('-', ind1+1 );   //finds location of second -
  data = readString.substring(ind1+1, ind2);   //captures data String
  Serial.print("my data is: ");
  Serial.println(data);
  int n = data.toInt();  //convert data into a number
  Serial.print("my number is: ");
  Serial.println(n);
  data=""; //clear data variable
yyaaayy !
readString was the way to go to be able to use indexOf !!
thanks for pointing me in the right direction !
you're the best :slight_smile:
