hello,
I am trying to connect my arduino uno + ethernet shield with mysql server. I have sensor dht11 and used php to do that. Can you help me. This is my code:
arduino code:
#include <DHT.h>
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // RESERVED MAC ADDRESS
EthernetClient client;
#define DHTPIN 2 // SENSOR PIN
#define DHTTYPE DHT11 // SENSOR TYPE - THE ADAFRUIT LIBRARY OFFERS SUPPORT FOR MORE MODELS
DHT dht(DHTPIN, DHTTYPE);
long previousMillis = 0;
unsigned long currentMillis = 0;
long interval = 250000; // READING INTERVAL
int t = 0; // TEMPERATURE VAR
int h = 0; // HUMIDITY VAR
String data;
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
dht.begin();
delay(10000); // GIVE THE SENSOR SOME TIME TO START
h = (int) dht.readHumidity();
t = (int) dht.readTemperature();
data = "";
void loop(){
currentMillis = millis();
if(currentMillis - previousMillis > interval) { // READ ONLY ONCE PER INTERVAL
data = "temp1=" + t;
data = data + "hum1=" + h;
if (client.connect("192.168.0.108",3306)) { // REPLACE WITH YOUR SERVER ADDRESS
client.println("POST /add.php HTTP/1.1");
client.println("Host: 192.168.0.108"); // SERVER ADDRESS HERE TOO
client.println("Content-Type: application/x-www-form-urlencoded");
client.print("Content-Length: ");
client.println(data.length());
client.println();
client.print(data);
if (client.connected()) {
client.stop(); // DISCONNECT FROM THE SERVER
delay(300000); // WAIT FIVE MINUTES BEFORE SENDING AGAIN
add.php =>
<?php include("connect.php"); $link=Connection(); $temp1=$_POST["temp1"]; $hum1=$_POST["hum1"]; $query = "INSERT INTO `tempLog` (`temperature`, `humidity`) VALUES ('".$temp1."','".$hum1."')"; mysql_query($query,$link); mysql_close($link); header("Location: index.php"); ?>connect.php =>
<?php function Connection(){ $server="localhost"; $user="root"; $pass="fifa2005"; $db="test"; $connection = mysql_connect($server, $user, $pass); if (!$connection) { die('MySQL ERROR: ' . mysql_error()); } mysql_select_db($db) or die( 'MySQL ERROR: '. mysql_error() ); return $connection; } ?>index.php =>
<?php include("connect.php"); $link=Connection(); $result=mysql_query("SELECT * FROM `tempLog` ORDER BY `timeStamp` DESC",$link); ?> Sensor DataTemperature / moisture sensor readings
<?php if($result!==FALSE){ while($row = mysql_fetch_array($result)) { printf("", $row["timeStamp"], $row["temperature"], $row["humidity"]); } mysql_free_result($result); mysql_close(); } ?>Timestamp | Temperature 1 | Moisture 1 |
%s | %s | %s |
MYSQL=>
