Arduino + Ethernet Shield | dude about if is possible
Hi to all!
I do some test with ard uno + ethernet shield. And im trying do that but dont know if that is posibble:
example: ip arduino 192.168.1.144 ip server 192.168.1.4
a daemon or cron access to: 192.168.1.144/led4=status
arduino give to server: 192.168.1.4/givestatus.php?led=4
My question is whether it is possible to client-server simultaneously. When I try to configure the server ip and client ip gives me error. Thank you!
Are you saying that you want the same ethernet port to be operating on 2 IP addresses?
If so,... I've never heard of any hardware that does this (let alone Arduino shields)
No, maybe explain me wrong. I mean if it's possible to put the request in the example:
web server accesses a web server ethernet arduino. Arduino send a client.print ("POST / blbla.php blblbla");
An ethernet shield can be a client and server in the same sketch, but on the same ip using different ports.
So there is no solution or alternative to do what I've described?
I was trying the following but does not work:
  [quote]
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,177);
 if (client.available()) {
        char c = client.read();
        Serial.write(c);
        if (c == '\n' && currentLineIsBlank) {:
          client.println("HTTP/1.1 200 OK"); // Enviar un encabezado de respuesta HTTP estándar
          client.println("Content-Type: text/html");
          client.println();
          client.println("<!DOCTYPE HTML>"); // Tipo de documento.
          client.println("<html>"); // Etiqueta html inicio del documento.
          client.print("Arduino!! - ");
           client.println("</html>"); // Etiqueta html fin del documento.
          client.print("POST http://192.168.1.4/test.php?hum=222 HTTP/1.0");
          client.println("User-Agent: Arduino 1.0");
          client.println();
Thanks again.
You need two instances of EthernetClient. One for the web server, and a separate instance for the client.
       IPAddress server(192,168,1,4);
      EthernetClient client2;
      if(client2.connect(server,80)) {
          client2.println("GET /test.php?hum=222 HTTP/1.0");
          client2.println("User-Agent: Arduino 1.0");
          client2.println();
edit: Corrected the syntax errors in the example.
Thanks again. But when i start to program and use:
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
EthernetServer server(80);
That give error.
sketch_jun13a:7: error: conflicting declaration 'EthernetServer server'
sketch_jun13a:6: error: 'server' has a previous declaration as 'IPAddress server'
Then delete the instance of the local variable "server" in the code.
edit: ...or use server2 like the client example I gave you if you need two instances.
Yeah i do work that, but now i have a new problem, full code:
#include <SPI.h>
byte mac[] = {
  while (!Serial) {
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
        Serial.write(c);
          client.println();
          send();
    delay(1);
    client.stop();
    Serial.println("client disonnected");
void send(){
    client2.println("GET /phpuser/dht.php?dht=1&temp=11&hum=432");
    client2.println(" HTTP/1.0");
    client2.println();
    Serial.println("Connect ok");
    Serial.println("connect fail");
  if (client2.connected()) {
  else {
    Serial.println("logout");
  client2.stop();
  client2.flush();
When i access to: http://192.168.1.177/
that add verys date to database and i only want one for visit:
see:
Thanks!
Finally that work:
#include <SPI.h>
byte mac[] = {
String readString=String(30);
  while (!Serial) {
  server.begin();
  EthernetClient cliente = server.available();
  if(cliente)
    boolean lineaenblanco=true;
    while(cliente.connected())//Cliente conectado
      if(cliente.available())
        char c=cliente.read();
        if(readString.length()<30)
          readString.concat(c);
        if(c=='\n' && lineaenblanco)
          int DHT = readString.indexOf("DHT=");
          if(readString.substring(DHT,DHT+5)=="DHT=1")
            send();
          cliente.println("HTTP/1.1 200 OK");
          cliente.stop();//Cierro conexión con el cliente
          readString="";
void send(){
    client2.println();
    //Serial.println("Connect ok");
  client2.stop();
  client2.flush();
