Arduino Ethernet Shield Just Won't Work
thank you for viewing. I am trying to obtain basic ethernet functionality from an Ardunio with Ethernet Shield so I can move on to the rest of my application. But no matter what, the ethernet just won't work! All of my hardware is brand new. I have tried both an Arduino UNO and a Mega 2560. I have three ethernet shields. They all produce the same result.. Nothing!
I have tried USB Power only, as well as 6V, 7.5V, and 9V DC on the DC jack. I'm scared to try 12V..
I am running Arduino IDE 1.6.7 on OS X El Capitan.
The LINK, 100M, and FDX LEDS will light when I plug into ethernet. I even see ACT flash when packets hit it.
I also know about writing Pin4 high to prevent SDCARD from interfering, but it had no effect, besides there is no card present.
I'm not sure what else to mention about the enviroment. On to the code.. Below is an example of code that does not work. It makes it into setup and prints "Serial Started" to the serial port, but never makes it through Ethernet.begin(mac, ip). I get the exact same results from the example code on any website I can find.. Ethernet.begin halts the program.
Any ideas? Things I missed? Thanks!
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x10, 0x31, 0xBF };
IPAddress ip(192,168,237, 2);
IPAddress gateway(192,168,237, 1);
IPAddress subnet(255, 255, 255, 0);
EthernetServer Server = EthernetServer(80);
  // Disable the SDCARD
  pinMode(4, OUTPUT);
  digitalWrite(4, HIGH);
  Serial.println("Serial Started");
  // start the Ethernet connection and the server:
  delay(250);
  Ethernet.begin(mac, ip);
  Server.begin();
  Serial.print("Server Started At ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  EthernetClient client = Server.available();
 if (client) {
    Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
  if (client.available()) {
    char c = client.read();
    Serial.write(c);
    if (c == '\n' && currentLineIsBlank) {
      client.println("Content-Type: text/html");
      client.println("Connection: close");
      client.println("Refresh: 5");
      client.println();
      client.println("<!DOCTYPE HTML>");
      client.println("<html>");
      // output the value of each analog input pin
      for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
        int sensorReading = analogRead(analogChannel);
        client.print("analog input ");
        client.print(analogChannel);
        client.print(" is ");
        client.print(sensorReading);
        client.println("
      client.println("</html>");
    if (c == '\n') {
    } else if (c != '\r') {
      currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
Do you have a link to where you bought your Ethernet shields? There are a few different Ethernet controller chips available on these shields and the Ethernet library only supports the W5100.
