It is also posted here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1268504939 - post 7
But i assume that Danish isnt your 2. language so i have translated the comments:
The Arduino Code:
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 88 };
byte gw[] = {192,168,1,1};
byte server[] = { xxx, xxx, xxx, xxx }; // Server IP
byte subnet[] = { 255, 255, 255, 0 };
int data = 0;
int tempPin = 2; // In This case the temperature is taken from pin 2 and sent to a sql server
pinMode(tempPin, INPUT);
Serial.begin(9600); // Used for serial debugging
Serial.println("Program running...");
delay(5000);
senddata(); // Data is sent every 5 seconds
void senddata()
data = analogRead(tempPin); //Reading analog data
Ethernet.begin(mac, ip, gw, subnet);
Client client(server, 80);
Serial.println("Forbinder?");
delay(1000); //Keeps the connection from freezing
if (client.connect()) {
Serial.println("Connected");
client.print("GET http://server.com/script.php?vaerdi=");
client.print(data);
client.println(" HTTP/1.1");
client.println("Host: www.server.com");
client.println();
Serial.println("Connection unsuccesfull");
//stop client
client.stop();
while(client.status() != 0)
delay(5);
PHP Code:
<html>
<?php
$DATA = $_GET['vaerdi'];
//Connect to database
$opendb = mysql_connect("xxx.xxx.xxx.xxx", "database", "password") or mysql_error("Could not connect to database");
mysql_select_db("database");
if ($opendb)
mysql_query(" INSERT INTO tabel (Dato, DATA) VALUES ( NOW() , $DATA )");
mysql_close($opendb);
</html>
In the MySql server there are 1 table with 2 datasets, one with the name DATA (Integer) and one with the name DATO (DATETIME)
I am not really good with mysql so if someone could tell how to get the MySql server to delete the oldest data i would be very happy
Also, this is not all my work, i modified it to my needs, but unfortunately i dont remember where i got if from..
- Christian
