arduino ethernet shield programming help pls
You will be using the Arduino Ethernet shield any HTTP GET request to the address will be discarded.the answer will return a string to be processed.If that returns the result as a string into the web address field again function as a string to be written.
I think funtion signature help pls
char* getTextFromURL(char* url); :o
If that is the homework assignment, the person that wrote that should be fired. Or, the person that translated it into English and discarded all the punctuation should be fired.
Ignoring what the client asked for is stupid. If one actually looks at the GET requests that a client makes when the Arduino is a server, a request for /, for /index.htm, and for favicon.ico (all typically requested) should NOT result in the same response.
The rest of that "requirement" makes no sense.
