Arduino Ethernet Shield velocità
salve a tutti, volevo sapere se il trasferimento dei dati tramite arduino ethernet shield è supportato per una velocità massima di 100Mbit/s, oppure quale sia la massima velocità ottenibile! grazie!
Non capisco la Tua domanda.
Il datasheet del W5100 dice:
http://www.mct.net/download/wiznet/w5100.pdf:
The W5100 is a full-featured, single-chip Internet-enabled 10/100 Ethernet controller
designed for embedded applications where ease of integration, stability, performance, area
and system cost control are required. The W5100 has been designed to facilitate easy
implementation of Internet connectivity without OS. The W5100 is IEEE 802.3 10BASE-T and
802.3u 100BASE-TX compliant.
The W5100 includes fully hardwired, market-proven TCP/IP stack and integrated Ethernet
MAC & PHY. Hardwired TCP/IP stack supports TCP, UDP, IPv4, ICMP, ARP, IGMP and PPPoE
which has been proven in various applications for several years. 16Kbytes internal buffer is
included for data transmission. No need of consideration for handling Ethernet Controller, but
simple socket programming is required.
Ciao Uwe
Se vuoi sapere la velocità effettiva di trasferimento dati, è poco più veloce di un modem trust 56k … 60-70k al sec :astonished:
Una scheggia :smiley:
Ciao
