Before making any changes to my roouter (HUAWEI B68A), I tried the webserver example to test the ethernet shield. Every thing works perfectly on local network.
After that, I tried to make it accessible from WAN and here i got some difficulties.
My router is synchronised with no-ip so my ip is "static".
After port forwarding, the arduino is no longer accessible from local network unless i add :portnumber after the ip adress.
When trying to access arduino from wlan (routerWANIPadress:portnumber) i get different different types of errors (such as: err connexion time out, or resource (ipadress) is online but does not respond to connexion request...)
I tried many things (disabled antivirus and firewall, changed port numbre or ip adress, used smartphone and pc, used arduino uno and mega...) but still no solution.
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
modified 02 Sept 2015
by Arturo Guadalupi
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 44);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(440);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("</html>");
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
** Router configuration:
Noip synchronisation :
Port forwarding:
Network security setting:
Serial communication (ok):
Local network test (ok):
WAN access test (error):
When running windows network diagnosis, it says that the ressource is online but does not respond to connexion attemps.
I tried DMZ activation et completely disabling the firewall but it is not working.
There is ACL window to set rules for connexion. Here i find http, https and icmp service types for lan, but only https for wan. could that be the problem?
when i use port 80, i can access the arduino web server directly from the ip adress from local network. when i use other prots, i need to add :portnumber after ip adress to access from local network, is that normal?
Some people say that such problem are related to my ISP (ooredoo) public ip management policy. i don't know if this is wright.
Yes.
i forgot to mention that i'm using a 3g connexion.
a friend of mine has just told me that i can not do portforwarding using a 3g connexion, is that true?
