I have this code that locally works perfect, but at the time of sending an external server, does not insert the data, who can help would be appreciated
#include <Ethernet.h>
#include <SPI.h>
#include <SDS011.h>
// Configuracion del Ethernet Shield
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFF, 0xEE}; // Direccion MAC
byte ip[] = { 192,168,1,101 }; // Direccion IP del Arduino
byte server[] = { 186,64,116,40 }; // Direccion IP del servidor
//byte server[] = { 192,168,1,36 }; // Direccion IP del servidor Externo
byte gw[] = {192, 168, 1, 1};
byte subnet[] = {255, 255, 255, 0};
EthernetClient client;
float p10,p25;
int error;
static const uint8_t D0 = 16;
static const uint8_t D1 = 5;
static const uint8_t D2 = 6;
static const uint8_t D3 = 0;
static const uint8_t D4 = 2;
static const uint8_t D5 = 14;
static const uint8_t D6 = 12;
static const uint8_t D7 = 13;
static const uint8_t D8 = 15;
static const uint8_t RX = 3;
static const uint8_t TX = 1;
SDS011 my_sds;
void setup(void) {
Ethernet.begin(mac, ip); // Inicializamos el Ethernet Shield
delay(1000); // Esperamos 1 segundo de cortesia
Serial.println("PM10 count,PM2.5 count,PM10 conc,PM2.5 conc");
my_sds.begin(D1,D2);
void loop(void) {
error = my_sds.read(&p25,&p10);
if (! error) {
Serial.println("P2.5: "+String(p25));
Serial.println("P10: "+String(p10));
// Proceso de envio de muestras al servidor
Serial.println("Connecting...");
if (client.connect(server, 80)>0) { // Conexion con el servidor
client.print("GET /simeco/modelo/rlectura.php?id=4&valor="); // Enviamos los datos por GET
client.print(String(p25));
client.print("&valor2=");
client.print(String(p10));
client.println(" HTTP/1.0");
client.println("User-Agent: Arduino 1.0");
client.println();
Serial.println("Conectado");
else {
Serial.println("Fallo en la conexion");
if (!client.connected()) {
Serial.println("Disconnected!");
client.stop();
client.flush();
delay(10000);
