I am just getting stared with arduino and have hit the wall.
I am trying to upload the example sketch but i get the following:
Binary sketch size: 2,542 bytes (of a 32,256 byte maximum)
H:\arduino-1.0.1\hardware/tools/avr/bin/avrdude -CH:\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM15 -b115200 -D -Uflash:w:C:\Users\User\AppData\Local\Temp\build4112558606665366331.tmp\AnalogReadSerial.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "H:\arduino-1.0.1\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM15
Using Programmer : stk500v1
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude done. Thank you.
I know that there were some sync problems with bootloader older than v4.4 but mine is 4.4. Here is the avrdude output:
avrdude -c arduino -p m328p -P COM15 -v
System wide configuration file is "H:\arduino-1.0.1\hardware\tools\avr\bin\avrdude.conf"
Using Port : COM15
Using Programmer : arduino
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f
avrdude: safemode: lfuse reads as 0
avrdude: safemode: hfuse reads as 0
avrdude: safemode: efuse reads as 0
avrdude: safemode: Fuses OK
Correct board and port are selected, I have double checked that. Can anyone tell me what am I doing wrong?
Update: when I open the serial monitor and reset arduino i can see ‘Reset done.’ messages. Only upload does not work
Solved! Here is the solution: http://code.google.com/p/arduino/issues/detail?id=649
