I am running a simple web server (static IP) based on the default web server example, which is occasionally interrupted by an external input (eg. RFID reader) which sends data as a client to another server in the local network and starting the server again. the device runs as intended for a few days but then stops responding to pin inputs, accessing the server page seems to get it back online (not sure about this) otherwise I am forced to manually reset when this happens.
Could using Serial Print(used during the debugging stage) without connecting a serial monitor be the issue?
