Does anybody know if the Arduino Ethernet (not the Ethernet shield) works with the WiFi shield cause I got both connected and when I try to run ScanNetworks, I'm getting 'WiFi shield not present'. I connected it to my pc with the UB2Serial Module.
You should have posted this under Networking, but since I am here...
No, they will not work together unless you do some pin bending and library mods. Both use D10 for the slave select.
I'm sorry I thought this would belong to the troubleshoot section. But thank you very much, you were right. I tried it on a Seeeduino and it works now.
As long as the moderators are ok with it being here, so am I. The point was that I may not have seen it.
