Arduino + Ethernet + Wifi
Hi guys, first post here :slight_smile:
I have a small project where I need to build a configuration that has both wifi + ethernet together.
I have been searching the forum to see if it is possible to use the arduino ethernet + an arduino wifi shield together.
Alternatively, I could also go for an arduino + ethernet shield + wifi shield.
From the specs, please correct if I am wrong, the arduino ethernet and the wifi shield have some common pins (11,12 and 13).
Does this "pin intersection" make them incompatible ?
Thanks in advance for any help or pointers,
Cheers
Why? If there is ethernet connection, why do you need wifi, too?
Imagine this little box is deployed to an end-user. The plan is to use the ethernet connection to gather data from this user and save/configure the wifi password to the box.
Otherwise, how would the arduino + wifi connect to the wireless router ?
thanks again for any help,
