I'm working on a sketch that lets me send commands to the Insteon SmartLinc PLM. The SmartLinc has a hidden port at 9761 that allows you to send Insteon and X10 commands directly to it and receive any commands sent to it from other devices. I've successfully done it in python but the Arduino Ethernet Library seems to have been designed mainly with HTTP in mind, and the SmartLinc isn't able to deal with the extra 2 bytes that the Ethernet Library appends to my command. My code is as follows:
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {0x90,0xA2,0xDA,0x00,0x5E,0xCF};
IPAddress server(192,168,0,108);
char command_on[] = {0x02,0x62,0x14,0xA1,0x15,0x0F,0x11,0xFF}; // Insteon command for light device on
char command_off[] = {0x02,0x62,0x14,0xA1,0x15,0x0F,0x13,0xFF}; // Insteon command for light device off
EthernetClient client;
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
for(;;)
Serial.println("Connecting...");
// connect to SmartLinc
if (client.connect(server, 9761)) {
Serial.println("Connected");
client.write(command_on); // Send just the command
else {
Serial.println("Connection Failed");
if (client.available()) {
byte c = client.read();
if (c < 16) // Just formats hex better for serial output (it drops the leading 0 in a hex byte if its < 16 and thats ugly)
Serial.print('0');
Serial.print(c,HEX); // print what is received in hex
Serial.print(' ');
Now this ALMOST works but here is my serial communication when sending:
Connecting...
Connected
02 62 14 A1 15 0F 11 FF 01 04 15
Now the hex it returned should be a duplicate of the command I sent, with 06 on the end(meaning the Insteon device received it successfully). The Arduino is sending the 2 extra 01 and 04 bytes which malform the command and an error is appended in the reply of 15.
So my question is: is there any way to disable these 2 bytes from being sent at the end of the write? (04 in ascii means End of Transmission so I'm assuming the arduino is doing this on purpose).
