Arduino Ethernet : working with FTDI adapter but not with external power
Hi there,
My project is pretty simple : I want to control a servo from an ethernet connection (a computer connected with ethernet)
Th servo is a DG servo S05NF
http://www.robotshop.com/eu/fr/servomoteur-s05nf-std.html
I've made this program
#include <SPI.h>         // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h>         // UDP library from: bjoern@cs.stanford.edu 12/30/2008
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 1;    // variable to store the servo position
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 10, 177);
unsigned int localPort = 8888;      // local port to listen on
// buffers for receiving data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
  // start the Ethernet and UDP:
  Ethernet.begin(mac,ip);
  Udp.begin(localPort);
  myservo.attach(6);  // attaches the servo on pin 7 to the servo object
  myservo.write(pos);
  // if there's data available, read a packet
  int packetSize = Udp.parsePacket();
  if(packetSize)
    // read the packet into packetBufffer
    Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);
    if (packetBuffer[0] == 'o') pos = 170;
    else if (packetBuffer[0] == 'f') pos = 3;
  if (pos>80) digitalWrite(9,HIGH);
  else digitalWrite(9,LOW);
  myservo.write(pos);
This is working when the board is connected (and powered) to the FTDI/usb adapter
BUT
when the board is powered from an external power adapter (I've try a 9v and a 12v). When I call the 0° position, the servo is reaching the 0° position, stand by half a second and reach the 180° back and is making noise like it's searching its position, and, about 2 seconds later stop searching (and making noise).
It's really curious.
I'm interested in any ideas.
How does the servo get its power? There is a signal, power and ground wire on the servo. Where is the power wire connected?
on the 5V pin of the arduino
taprik:
That is unwise. You should power it with an external power supply. Only ground and signal should be connected to the Arduino.
It's working with an external power supply.
Thank you SurferTim :slight_smile:
