io ho questo schema e riesco a far scattare un relè quando aziono l icona sul broswer.io vorrei azionarne altri due con la stessa funzione ma nn so come si fa... =( naturalmente con un altro http...
questo e lo sketch:
// -*- c++ -*-
// Copyright 2010 Ovidiu Predescu <ovidiu@gmail.com>
// Date: December 2010
#include <SPI.h>
#include <Ethernet.h>
#include <Flash.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <TinyWebServer.h>
// The LED attached in PIN 7 on an Arduino board.
const int ledPin = 7;
// The initial state of the LED
int ledState = LOW;
void setLedEnabled(boolean state) {
ledState = state;
digitalWrite(ledPin, ledState);
inline boolean getLedState() { return ledState; }
boolean file_handler(TinyWebServer& web_server);
boolean blink_led_handler(TinyWebServer& web_server);
boolean led_status_handler(TinyWebServer& web_server);
boolean index_handler(TinyWebServer& web_server);
TinyWebServer::PathHandler handlers[] = {
// Work around Arduino's IDE preprocessor bug in handling /* inside
// strings.
// `put_handler' is defined in TinyWebServer
{"/", TinyWebServer::GET, &index_handler },
{"/upload/" "*", TinyWebServer::PUT, &TinyWebPutHandler::put_handler },
{"/blinkled", TinyWebServer::POST, &blink_led_handler },
{"/ledstatus" "*", TinyWebServer::GET, &led_status_handler },
{"/" "*", TinyWebServer::GET, &file_handler },
{NULL},
const char* headers[] = {
"Content-Length",
NULL
TinyWebServer web = TinyWebServer(handlers, headers);
boolean has_filesystem = true;
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
static uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// Don't forget to modify the IP to an available one on your home network
byte ip[] = { 192, 168, 1, 50 };
void send_file_name(TinyWebServer& web_server, const char* filename) {
if (!filename) {
web_server.send_error_code(404);
web_server << F("Could not parse URL");
TinyWebServer::MimeType mime_type
= TinyWebServer::get_mime_type_from_filename(filename);
web_server.send_error_code(200);
web_server.send_content_type(mime_type);
web_server.end_headers();
if (file.open(&root, filename, O_READ)) {
Serial << F("Read file "); Serial.println(filename);
web_server.send_file(file);
file.close();
web_server << F("Could not find file: ") << filename << "\n";
boolean file_handler(TinyWebServer& web_server) {
char* filename = TinyWebServer::get_file_from_path(web_server.get_path());
send_file_name(web_server, filename);
free(filename);
return true;
boolean blink_led_handler(TinyWebServer& web_server) {
web_server.send_content_type("text/plain");
// Reverse the state of the LED.
setLedEnabled(!getLedState());
Client& client = web_server.get_client();
if (client.available()) {
char ch = (char)client.read();
if (ch == '0') {
setLedEnabled(false);
} else if (ch == '1') {
setLedEnabled(true);
} doSomething();
Serial << F("APRO GARAGE\n");
void doSomething()
digitalWrite(7, LOW);
digitalWrite(7, HIGH);
boolean led_status_handler(TinyWebServer& web_server) {
client.println(getLedState(), DEC);
boolean index_handler(TinyWebServer& web_server) {
send_file_name(web_server, "INDEX.HTM");
return true;
void file_uploader_handler(TinyWebServer& web_server,
TinyWebPutHandler::PutAction action,
char* buffer, int size) {
static uint32_t start_time;
static uint32_t total_size;
switch (action) {
case TinyWebPutHandler::START:
start_time = millis();
total_size = 0;
if (!file.isOpen()) {
// File is not opened, create it. First obtain the desired name
// from the request path.
char* fname = web_server.get_file_from_path(web_server.get_path());
if (fname) {
Serial << F("Creating ") << fname << "\n";
file.open(&root, fname, O_CREAT | O_WRITE | O_TRUNC);
free(fname);
case TinyWebPutHandler::WRITE:
if (file.isOpen()) {
file.write(buffer, size);
total_size += size;
case TinyWebPutHandler::END:
file.sync();
Serial << F("Wrote ") << file.fileSize() << F(" bytes in ")
<< millis() - start_time << F(" millis (received ")
<< total_size << F(" bytes)\n");
file.close();
Serial << F("Free RAM: ") << FreeRam() << "\n";
pinMode(ledPin, OUTPUT);
// initialize the SD card
Serial << F("Setting up SD card...\n");
pinMode(10, OUTPUT); // set the SS pin as an output (necessary!)
digitalWrite(10, HIGH); // but turn off the W5100 chip!
if (!card.init(SPI_FULL_SPEED, 4)) {
Serial << F("card failed\n");
has_filesystem = false;
// initialize a FAT volume
if (!volume.init(&card)) {
Serial << F("vol.init failed!\n");
if (!root.openRoot(&volume)) {
Serial << F("openRoot failed");
if (has_filesystem) {
// Assign our function to `upload_handler_fn'.
TinyWebPutHandler::put_handler_fn = file_uploader_handler;
Serial << F("Setting up the Ethernet card...\n");
Ethernet.begin(mac, ip);
// Start the web server.
Serial << F("Web server starting...\n");
web.begin();
Serial << F("Ready to accept HTTP requests.\n");
web.process();
