Arduino Ethernet
good Afternoon
This code is my graduation project in which I blow a fan and this indicator crosses an optical sensor, the thing that well to that. The thing is that you connect to an ethernet shield, the communicating me but there is a line of code that is not where to locate it is to:
if (digitalRead (2) == LOW)
conta ++;
Serial.println (conta);
client.println (conta);
delay (1000);
I show the code, because where ubice not work and the first result is maintained.
  Web Server
 A simple web server that shows the value of the analog input pins.
 using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 * Analog inputs attached to pins A0 through A5 (optional)
 created 18 Dec 2009
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,2);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
int conta = 0;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
	  client.println("Refresh: 1");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 1; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
  if (digitalRead(2) == LOW)
        conta++;
        Serial.println(conta);
        delay(100);
 if (conta<4)
    client.println("<body>");
    client.println("<h1 align='center'>ESPIROMETRO</h1><h3 align='center'>SENSOR controlado por Servidor Web con Arduino</h3>");
    client.println("
    client.print("RESULTADO!! - :");
    client.println("
    client.print("Muy Baja Cap");
    client.println("
    client.print("Consulta 1 App");
    client.println("
  if (conta>5 && conta<7)
    client.print("Baja Capacidad");
    client.println("
    client.print("Consulta 2 App");
    client.println("
  if (conta>8 && conta<20)
    client.print("Capacidad estable");
    client.println("
    client.print("Consulta 3 App");
    client.println("
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
    client.println("
Does that look like intelligent indenting or does that look like crap to you? It looks like crap to me.
Your translator needs new batteries.
