Hello!
I need to control 7 segment (3 digit) on webpage by textbox . :~
my condition
if i need to show "999" on 7 segment, I will insert "999" in textbox then i click button to send "999" to 7 segment and show current 7 segment number on webpage also.
now, I can set "999" to show no 7 segment by fix code but i can't create textbox an send "999" to 7 segment as my condition because i don't know how to ?
somebody can you help me, please
sorry about my English is not well (so bad) XD
This is some mycode
#include "etherShield.h"
static uint8_t mymac[6] = {0x54,0x55,0x58,0x10,0x00,0x24};
static uint8_t myip[4] = {192,168,1,15};
static char baseurl[]="http://192.168.1.15/";
static uint16_t mywwwport =80; // listen port for tcp/www (max range 1-254)
#define BUFFER_SIZE 500
static uint8_t buf[BUFFER_SIZE+1];
#define STR_BUFFER_SIZE 22
static char strbuf[STR_BUFFER_SIZE+1];
EtherShield es=EtherShield();
uint16_t print_webpage(uint8_t *buf, byte on_off);
uint16_t display_digit(uint16_t ds1);
int8_t analyse_cmd(char *str);
// Use 3 74HC595 shift registers to display 3 numbers
int LatchPin = 5;
int ClockPin = 6;
int DataPin = 7;
char m[4];
byte data;
byte dataArray[10];
void setup(){
pinMode(LatchPin, OUTPUT);
pinMode(ClockPin, OUTPUT);
pinMode(DataPin, OUTPUT);
/*initialize enc28j60*/
es.ES_enc28j60Init(mymac);
es.ES_enc28j60clkout(2); // change clkout from 6.25MHz to 12.5MHz
delay(10);
es.ES_enc28j60PhyWrite(PHLCON,0x880);
es.ES_enc28j60PhyWrite(PHLCON,0x990);
es.ES_enc28j60PhyWrite(PHLCON,0x476);
delay(100);
es.ES_init_ip_arp_udp_tcp(mymac,myip,80);
display_digit(000);
void loop(){
uint16_t plen, dat_p;
int8_t cmd;
byte on_off = 1;
int8_t Actual=0;
plen = es.ES_enc28j60PacketReceive(BUFFER_SIZE, buf);
if(plen!=0){
if(es.ES_eth_type_is_arp_and_my_ip(buf,plen)){
es.ES_make_arp_answer_from_request(buf);
return;
if(es.ES_eth_type_is_ip_and_my_ip(buf,plen)==0){
return;
if(buf[IP_PROTO_P]==IP_PROTO_ICMP_V && buf[ICMP_TYPE_P]==ICMP_TYPE_ECHOREQUEST_V){
es.ES_make_echo_reply_from_request(buf,plen);
return;
// tcp port www start, compare only the lower byte
if (buf[IP_PROTO_P]==IP_PROTO_TCP_V&&buf[TCP_DST_PORT_H_P]==0&&buf[TCP_DST_PORT_L_P]==mywwwport){
if (buf[TCP_FLAGS_P] & TCP_FLAGS_SYN_V){
es.ES_make_tcp_synack_from_syn(buf); // make_tcp_synack_from_syn does already send the syn,ack
return;
if (buf[TCP_FLAGS_P] & TCP_FLAGS_ACK_V){
es.ES_init_len_info(buf); // init some data structures
dat_p=es.ES_get_tcp_data_pointer();
if (dat_p==0){ // we can possibly have no data, just ack:
if (buf[TCP_FLAGS_P] & TCP_FLAGS_FIN_V){
es.ES_make_tcp_ack_from_any(buf);
return;
if (strncmp("GET ",(char *)&(buf[dat_p]),4)!=0){
// head, post and other methods for possible status codes see:
// http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html
plen=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n<h1>200 OK</h1>"));
goto SENDTCP;
if (strncmp("/ ",(char *)&(buf[dat_p+4]),2)==0){
plen=print_webpage(buf, on_off);
goto SENDTCP;
cmd=analyse_cmd((char *)&(buf[dat_p+5]));
if (cmd==2){
on_off=1;
display_digit(000);
else if (cmd==3){
on_off=0;
display_digit(999);
SENDTCP: es.ES_make_tcp_ack_from_any(buf); // send ack for http get
es.ES_make_tcp_ack_with_data(buf,plen); // send data
///------------------- 7 segment function-------------------------//
uint16_t digit[3],i,loop_digit,dis;
char num_led[17] = {0x3F,0x06,0x5B,0x4F,0x66,
0x6D,0x7D,0x07,0x7F,0x6F,
0x77,0x7C,0x39,0x5E,0x79,
0x50,0x80};
digit[0] = num_led[ds1%10];
digit[1] = num_led[(ds1/10)%10];
digit[2] = num_led[(ds1/100)%10];
digitalWrite(ClockPin, LOW);
digitalWrite(LatchPin, HIGH);
for(loop_digit=0;loop_digit<3;loop_digit++)
dis = digit[loop_digit];
for(i=0;i<8;i++)
if((dis&0x80)==0)
digitalWrite(DataPin, LOW);
digitalWrite(DataPin, HIGH);
dis=dis<<1;
digitalWrite(ClockPin, HIGH);
digitalWrite(LatchPin, LOW);
///---------------------End of 7 segment function-----------------------//
uint8_t find_key_val(char *str,char *key)
uint8_t found=0;
uint8_t i=0;
char *kp;
kp=key;
while(*str && *str!=' ' && found==0){
if (*str == *kp){
kp++;
if (*kp == '\0'){
str++;
kp=key;
if (*str == '='){
found=1;
}else{
kp=key;
str++;
if (found==1){
while(*str && *str!=' ' && *str!='&' && i<STR_BUFFER_SIZE){
strbuf[i]=*str;
i++;
str++;
strbuf[i]='\0';
return(found);
int8_t r=-1;
if (find_key_val(str,"cmd")){
if (*strbuf < 0x3a && *strbuf > 0x2f){
// is a ASCII number, return it
r=(*strbuf-0x30);
return r;
///--------------------- Webpage -----------------------//
int i=0;
uint16_t plen;
plen=es.ES_fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<center><p><h1>Counter Boards Monitoring</h1></p> "));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<hr>
<form METHOD=get action=\""));
plen=es.ES_fill_tcp_data(buf,plen,baseurl);
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("\">"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<h2> Counter board is </h2> "));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<h1><font color=\"#00FF00\"> "));
if(on_off)
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("Target"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("Actual"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR(" </font></h1>
if(on_off){
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=hidden name=cmd value=3>"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=submit value=\"Set Target\"></form>"));
else {
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=hidden name=cmd value=2>"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("<input type=submit value=\"Actual\"></form>"));
plen=es.ES_fill_tcp_data_p(buf,plen,PSTR("</center><hr> <p>Counter boards monitoring V.1 <a href=\"http://www.XXX.co.th\">http://www.XXX.co.th<a>"));
return(plen);
