Arduino.exe in Windows XP SP3 fails to start!
I just bought my first Arduino down at the local Radio Shack. Once, home I immediately started setting it up by following the guide here: http://arduino.cc/en/Guide/Windows. Everything was going well until I reached step 5 (Launch the Arduino application). When I double-clicked the application, the splash screen popped up for a couple seconds then went away and then nothing opened. Repeated attempts resulted this way as well.
What might the problem with this be?
Thanks,
There seem to be a few reports of that, yet thousands of others have no problems.
Where did you put the install files? Can you try running as administrator?
I just found out that the extraction process failed for some reason causing some files to not be extracted! All I did to fix it was delete all of the files then re-extract and voila.
All is well now :)
Thanks!
