Hi everybody I have an if statement with 3 conditions
if (erreur == 0 && presencebloc == false && proxsensorstate == LOW)
The problem is that even if I put my variable erreur = 1 the if statement get executed which is against the first condition. I hope one of you guys have seen this before. If you need the full code just ask me. Thx in advance!
Put the complete code because I can not reproduce the problem, if I change the value of any of the 3 variables the condition is not fulfilled (as expected)
This is missing the braces "{" and "}" around the statements following the "if" condition test
// xfpd
erreur = 1;
if (erreur == 0 && presencebloc == false && proxsensorstate == LOW) // NOT ENCLOSED IN BRACES { }
Serial.println("This line will print if all conditions evaluate to true");
Serial.println("This line will always print, even when erreur = 1");
And this one... with the semi-colon "closing" the "if" condition.
// build_1971
erreur = 1;
if (erreur == 0 && presencebloc == false && proxsensorstate == LOW); // <- THIS semicolon closes the 'if' condition, so...
#include <Stepper.h>
int stepEtiquette = 0;
//const int jogEtiquette = ;
const int jogHoraire = 49;
const int jogAntiHoraire = 50;
//const int jogEjecteur = 13;
const int modeAuto = 51;
const int stepsEtiquette = 400;
Stepper myStepper(stepsEtiquette, A0, A1, A2, A3);
const int proxsensor = 29;
const int balayeuse = 26;
const int ejecteur = 22;
const int verintoupie = 24;
const int verinbloc = 23;
const int spindle = 25;
const int dirpin = 28;
const int steppin = 13;
const int enablestepper = 27;
bool presencebloc = false;
int erreur;
int stepPerRev = 6000; //
const int delaiEntrePulse = 1600;
const int delaivitesserapide = 550; //détermine la vitesse du stepper plus le chiffre est gros plus il est lent(delaymicroseconds)
const int durePulse = 5;
const int startangle = 750;
int backlash = 250;
int proxsensorstate = 0;
myStepper.setSpeed(100);
pinMode(proxsensor, INPUT_PULLUP);
pinMode(modeAuto, INPUT_PULLUP);
// pinMode(jogEtiquette, INPUT_PULLUP);
// pinMode(jogEjecteur, INPUT_PULLUP);
pinMode(jogHoraire, INPUT_PULLUP);
pinMode(jogAntiHoraire, INPUT_PULLUP);
pinMode(ejecteur, OUTPUT);
pinMode(balayeuse, OUTPUT);
pinMode(verintoupie, OUTPUT);
pinMode(verinbloc, OUTPUT);
pinMode(spindle, OUTPUT);
pinMode(dirpin, OUTPUT);
pinMode(steppin, OUTPUT);
pinMode(enablestepper, OUTPUT);
Serial.println("booting");
while (erreur == 1 || digitalRead(modeAuto) == LOW) {
modeManuel();
while (erreur == 0 && digitalRead(modeAuto) == HIGH) {
proxsensorstate = digitalRead(proxsensor);
digitalWrite(enablestepper, HIGH); //désactive la drive du stepper pour pas quelle surchauffe lorsque la machine est en attente
if (proxsensorstate == LOW) {
digitalWrite(balayeuse, HIGH);
digitalWrite(balayeuse, LOW);
if (erreur == 0 && presencebloc == false && proxsensorstate == LOW) {
digitalWrite(enablestepper, LOW); //active la drive du stepper pour eviter qu'il bouge si un bloc lacroche legerement pendant qu'il se met en position.
//etiquette();
ejection();
if (proxsensorstate == HIGH) { //sert a faire en sorte que si le bloc reste prit dans la chute, la boucle d'éjection se repete
presencebloc = true;
delay(50);
Serial.println(presencebloc);
// pour evité quil retourne dans la boucle d'éjection a cause du scan time rapide et laisse le verin rentré
digitalWrite(verinbloc, LOW);
digitalWrite(ejecteur, LOW);
digitalWrite(spindle, LOW);
erreur = 1; //lorque lejection du bloc foire au lieu de reeassayer et de tout briser larduino imcremente la varible erreur qui renvoi au mode manuel ce qui necessite un reset
Serial.println(erreur);
modeManuel();
if (presencebloc == true) {
digitalWrite(verinbloc, HIGH);
substartangle(); // met le bloc en angle pour recevoir la toupie
digitalWrite(verintoupie, HIGH);
delay(500); //Pour que les toupies soient bien sur le bloc
tourRectification();
digitalWrite(verintoupie, LOW);
remetblocdroit();
delay(350);
delay(350); //laisse le temps au machoire de remonter pour eviter que le bloc soit laché croche
resetverinbloc();
presencebloc = false; //pour etre sur que la variable presence bloc soit = a 0
delay(50);
digitalWrite(enablestepper, HIGH); // désactive la drive du stepper
void ejection() {
digitalWrite(spindle, HIGH);
digitalWrite(ejecteur, HIGH);
Serial.println("ejecteur sort");
delay(1600);
delay(200); // pour etre sur que le la blocest bien aggriper par les machoires
}[quote="doingmybest, post:1, topic:1241695, full:true"]
Here is most of the code I left out some functions that are not problematic.
[/quote]
Damn I am pretty sure that you are right in modeManual() I wrote erreur=0 because I wanted to be able to reset the error by flipping the switch to manuel mode. I feel so stupid I am gonna modify the modeManual funtion and keep you informed if it works(pretty sure it will)
