Hello, I am a student currently working on my project. However, I have encountered a problem and would like to seek your possible solutions. Thank you; your answers are greatly appreciated.
Welcome to the forum
More details please
Which Arduino board do you have ?
Which version of the IDE are you using ?
Which board is selected in the IDE ?
Please read the advice in the topic "How to get the best from this forum". How to get the best out of this forum
I cannot read your post so "No Can Help" at this point.
Do you see the "COPY ERROR MESSAGES" button in your screenshot ? Use it and post what is copied in a new reply here using code tags when you do
I'm using arduino mega 2560.
Sketch uses 19278 bytes (7%) of program storage space. Maximum is 253952 bytes. Global variables use 1812 bytes (22%) of dynamic memory, leaving 6380 bytes for local variables. Maximum is 8192 bytes. avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_ReceiveMessage(): timeout avrdude: stk500v2_getsync(): timeout communicating with programmer Failed uploading: uploading error: exit status 1
The purpose of this project is to create a fingerprint attendance system.
- Did upload work in the past?
- Anything connected to pins 0 and 1? This will interfere with the upload so disconnect and try again.
- Anything else connected? Disconnect it and try again. If yes, what else is connected?
- Is COM3 indeed the Mega? Does the port disappear from the IDE's ports menu when you disconnect the board?
- If your board does not use the CH340 serial-to-usb converter but e.g. 16U2, what is the result of the loopback test?
- If you tap the reset button on the board, does the L-LED flash a couple of times?
I've moved your topic to the section of the forum that is dedicated to this type of problems.
The thread title is misleading , there is no any "exit status problem".
it is just an upload error
- Yes, and it works fine.
- Nothing is connected.
- The only components that are connected are LCD I2C and AS608.
- Yes, it is on COM3, but the port does not disappear even if it is disconnected.
- I don't know what this is.
- Yes, it blinks.
Thank you for your time just to reply.
If it does not disappear when disconnected, it's not the Arduino. I have no idea how to sort that out.
What does Windows think of your board? Check Windows device manager with and without the board connected.
Follow the link; but it's not useful if you can't find the correct port.
I am sorry; I am new here, and I will take note of this to improve. Thank you for letting me know.
Thank you very much for your time to help.
