I maintain this fork, added some commits recently
Thanks for the effort! Keep it alive! I'd be glad to contribute.
You are more than wellcome to contribute.
I am also trying to make development more easy, there is a docker file in the repo that creates a full build environment, hopefully soon there will be also a docker image to download from docker hub
I am using the microsoft module with Cursor. (is folk of VsCode for AI)
The integration with AI Writing code, correction, auto-completion is spectacular.
I didn't understand which Folk you are talking about.
I could not get rid of the error that cannot find strstr() and the like.
I tried so many directories but nothing, in the end I disabled the errors.
The compilation works, only the editor shows me that it cannot find it.
Zero, SAMD21
"includePath": [
"${workspaceFolder}/**",
"D:/Documenti/Arduino/libraries/**",
"D:/Documenti/Arduino/libraries/*/**",
"C:/Users/x-gio/AppData/Local/Arduino15/packages/arduino/hardware/samd/1.8.14/cores/arduino",
"C:/Users/x-gio/AppData/Local/Arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/",
"C:/Users/x-gio/AppData/Local/Arduino15/packages/arduino/hardware/samd/1.8.14/variants/arduino_zero",
"C:/Users/x-gio/AppData/Local/Arduino15/packages/arduino/hardware/samd/1.8.14/cores/arduino/api",
"C:/Users/x-gio/AppData/Local/Arduino15/packages/arduino/hardware/samd/1.8.14/libraries/SPI",
"C:/Users/x-gio/AppData/Local/Arduino15/packages/arduino/hardware/samd/1.8.14/cores/arduino/api/deprecated",
"C:/Users/x-gio/AppData/Local/Arduino15/packages/arduino/hardware/samd/1.8.14/cores/arduino/api/deprecated-avr-comp"
Now I understand, I am already using the community version.
There is an error on the presentation page pointing to the link to the microsoft version.
How do I solve that the editor cannot find the standard C libraries?
Are you all dead?
Has anyone tested whether it still works with the IDE update?
Arduino CLI v1.1.1
Can skip verify before upload (#2397)
Implement menu action to reload current board data (#2553)
Add donate footer to updater dialog (71b11ed8, #2581)
Add dialog to introduce to new version (4788bfbc, #2581)
Changed
Use Arduino CLI v1.1.1 (#2576)
Use Ubuntu 18.10 in Linux build container (#2307)
Fixed
Retry compilation if grpc client needs to be reinitialized (#2548)
Fix memory leak when scanning sketchbooks with large files (#2555)
Disable local windows signing for forks PR (#2554)
Align viewsWelcome behavior to VS Code (#2543)
Fix CLI error parsing (#2518)
Thanks to everyone who's helping us improve the quality of Arduino IDE:
@dankeboy36
The original microsoft vscode-arduino code has a remote code execution vulnerability. Please see the link below for details.
https://msrc.microsoft.com/update-guide/vulnerability/CVE-2024-43488
Hello everyone,
I have some good news to share! A new plugin for Arduino development in Visual Studio Code is now available. It’s called Arduino Maker Workshop by TheLastOutpostWorkshop.
I’ve personally tested it, and it’s working perfectly. If you’re looking for an alternative, this might be worth checking out.
This extension is awesome. Tried it with VS Code in both Linux and Windows for both Arduino and custom AVR MCU based board programming, it rocks. There are two things that must be done though: 1) dedicated bootloader flashing and 2) a possibility to create a new sketch in user selected directory. Empty one or based on example from either basic examples or selected board examples.
Hi @krotow.
If you have a GitHub account, I would recommend submitting the feature request for this to the issue tracker in the extension's repository:
The extension developer does a great job of maintaining the issue tracker and community members may also take the initiative to contribute the implementations for features tracked there.
In case it will be helpful, there are some instructions for creating a new sketch here:
https://github.com/thelastoutpostworkshop/arduino-maker-workshop/issues/33#issuecomment-2628911761
There are several ways to that, here is one:
- In VS Code, open a folder where you want sketch to be stored (File > Open Folder)
- Open the Arduino Maker Workshop Home tab, it will ask you to create a new sketch, this will create a new sketch inside the folder you opened before.
I understand that ideally it would have a capability similar to Arduino IDE, where we only need to select File > New Sketch from the menus to create a new sketch, instead of needing to perform multiple operations in sequence.
