ARduino external programming
After programming the arduino uno can i take out the programmed microcontroller out of the uno board ,and use it in a normal circuit?...Will it work accordingly?
Yes if you add...
  • 16 MHz crystal + appropriate capacitors or a 16 MHz resonator
  • 0.1 uF capacitor across VCC and GND as close as possible to the processor
  • 0.1 uF capacitor across AVCC and AGND as close as possible to the processor
  • 10 kohm resistor from reset to VCC (+5V)
You will need to connect...
  • Both VCC and AVCC to +5V
  • Both GND and AGND to ground
Yes. Assuming the "normal circuit" has the required bits and pieces (in particular, a correct 16MHz crystal or resonator.)
This may help...
https://www.google.com/search?q=arduino+standalone
