Arduino fails occasionally to start executing script
Hi all,
Problem described in the title.
I do data logging and it's extremely frustrating when I set everything up for a weekend of measuring and when I come back, I see nothing has been logged. Everything seems to be ok visually (LEDs on). There is nothing indicating that something could be wrong. I know that I should probably add some kind of debugging LED just to see that the script is running, but still I'm a bit bitter.
Anyone else experienced anything similar? Could It be a psu related problem (using regulated 8vdc atm.)? Most of the time everything works fine, but every now and then I get these weird mishaps.
(deleted)
spycatcher2k:
I think its the green wire OR line 74 of your code.
See the issue with your question yet :slight_smile:
So you got your crystal ball back from repair SC...Working great eh !
Sry guys, forgot to post the code.
#include "Wire.h"
#include <RTClib.h>
RTC_DS1307 RTC;
const int chipSelect = 10; // Adafruit 10 - Arduino 4
#include <SPI.h>
#include <SD.h>
int dp_count = 100;
float dp_val = 0;
float val_TMP = 0;
int pin = 2;
int time = 30000;
  Wire.begin();
  RTC.begin();
  pinMode(10,OUTPUT);
  pinMode(2,OUTPUT);
  if (!SD.begin(chipSelect)) {
    return;}
  File dataFile = SD.open("data.txt", FILE_WRITE);
    if (dataFile){
      dataFile.close();}
  checkStatus();
  differentialPressure();
  checkStatus();
  TMP36();
  checkStatus();
  saveSD();
  blinkStatus();
  delay(time);
void TMP36(){
  val_TMP = ((analogRead(A1) * 0.004882814) - 0.5) * 100.0;
void differentialPressure() {
  dp_val = 0;
  for(int i=0; i<dp_count; i++){
    dp_val = dp_val + analogRead(A0);
    delay(5);}
  dp_val = dp_val / dp_count;}
void checkStatus(){
   float starttime = millis();
   while ((millis()-starttime) < 1500){
    digitalWrite(pin, HIGH);
    delay(20);
    digitalWrite(pin, LOW);
    delay(20);}
void blinkStatus(){
  for (int i=0; i<3; i++){
    delay(800);
    delay(800);}
void saveSD(){
  DateTime now = RTC.now();
  File data = SD.open("data.txt", FILE_WRITE);
  if (data){
    data.print(now.month(), DEC);
    data.print('/');
    data.print(now.day(), DEC);
    data.print('/');
    data.print(now.year(), DEC);
    data.print(' ');
    data.print(now.hour(), DEC);
    data.print(':');
    data.print(now.minute(), DEC);
    data.print(':');
    data.print(now.second(), DEC);
    data.print(" ");
    data.print("\t");
    data.print(dp_val);
    data.print("\t");
    data.println(val_TMP);
    data.close();}
I'm a bit sceptical that the problem is in the code. As I said, everything works fine at lab. All wiring has been tested and proved also.
E: btw. can a long delay() (i.e. >5min) have a negative impact on reliability?
Just a note:
You might want to rethink not using comments in your sketches.
Stop using delay()s they stop every thing for that time.
Put { and } on a line by themselves.
