Arduino & Feather RP2040 + Earle Philhower: HowTo and Learnings
I spent two weeks learning how to get [Arduino & Feather RP2040 & Earle Philhower's core] working, migrating my sketch from a nano Every... In the process, I declared the hardware as 'bad' and almost gave up on this part at least 3 times. However, the hw is great - it is a matter of understanding how the part behaves, partially correct documentation and being among the first ones to use this. I tried using the VSCode IDE, but gave up as PlatformIO does not yet officially support Philhowers board package (mid december 2021).
  1. When the code crashes, the Serial Port is gone! This implies you have to use the bootsel button to get the drive port back - but then the Arduino IDE cannot load the new FW. I then first load the circuit python UF2 file to get the port back. Yikes. And, the RP2040 is much quicker to crash than a Nano. The RP2040 is much less forgiving with sloppy code than classical arduinos...
  2. An INT is not an INT. On the Nano, the INT is 16 bits, on the RP2040 it is 32 bits. When converting an INT to a string, the result can produce very long strings, and exceed the allocated char array size (using itoa() ). On the Nano, given small amount of RAM I had the char[.] at smallest required sizes. I migrated the code to RP2040 and exceeded the string length due to unexpected INT values. This crashed the code (see 1.). Furthermore, some of my INTs are dynamically allocated (malloc()) so the values survive a reset (I use these INTs for time and date). This lead to a situation that crashed the RP2040 with a power cycle (not on a reset cycle!), and convinced me at first that the flash gets corrupted on a power cycle. When reflashing, the code did not crash, as loading the new fw zeroed out the dynamic INTs. However, it was my sloppy code: flash is not corrupted (it was my brain...!). This took me 3 days to find out.
  3. Using the second core with loop1(): I only got this to work using Philhowers setup. Not in stock arduino.
  4. No default pins on spi1. I need both spi ports as the SD library and CC1101 libraries bite each other on the RP2040 (Not on the Nano!). Using Philhowers setup, I was able to modify the CC1101 library to use spi1(). However the .setRX() etc methods did not work. I ended up setting the RP2040 configuration registers directly to solve that issue. That works: however do it before SPI1.begin(). That took me 3 days to get working. See the RP2040 datasheet from RaspberryPi.
  5. Setting SPI speed with .beginTransaction() does not work. Again, I access the registers directly. See the RP2040 datasheet from RaspberryPi.
22 Dec 2021 (I may add further points in future).
Notes: I wanted to buy the Raspberry Pico, but shipping costs were 3 times the part costs (don't know what they were smoking). So I ordered the adafruit part thru digikey with reasonable shipping costs. The Arduino RP2040 connect has wifi+bt that I dont need and want to pay for. And too high shipping costs.
Philhower docu: Installing the Earle Philhower core | Program RP2040 in Arduino | Adafruit Learning System
@ronaldgadget
I'm not really sure where the best place for this is, but certainly not introductory tutorials, for that is what it is not.
I've moved to Bar Sport as that seemed like the best place for now.
Hi @ronaldgadget, Many thanks for sharing this!
I have been struggling to swap to alternate pins using Philhowers core. Would you be willing to share the direct register access method you have implemented?
UPDATE: just update the package to 1.13.1 and it works perfectly (thanks the Earle for his support)
