Arduino - Firmata, not working correctly
Hi !
I made a program that uses a UDP library, and Firmata (processign 1.51 + Arduino 0.22).
I tried it on another computer and it doesn't work correctly.
When i'm using the firmata example (PWM), or with a custom program, when i use an analoguewrite command, the led flickers !
I tried different versions of firmata, and processing (i can't use 2.x because of my 1.51 udp library, and the x64 version doesn't include serial communications)
How can i solve this ?
Thanks !
Pierre :slight_smile:
But, you are not going to share them?
Fix the code that doesn't work.
Don't be mad !
Here's the code
import processing.serial.*;
import cc.arduino.*;
Arduino arduino;
  size(10, 10);
  arduino = new Arduino(this, Arduino.list()[0], 57600);
void draw() {
  arduino.analogWrite(3,10);
// i tried to use delays , nothing changed ...
When i do this, my led connected on the third pin is blinking !
All of my previous programms worked like a charm, but now that i've got a new PC, it doesn't work anymore.
You got a new PC, and installed old software on it. Why? You should be using 1.0.3, or the just released 1.0.4.
Actually i tried a lot of things:
All builds of arduino since 0.20 to 1.5.1 , mixed with processing from 1.5.1 to 2.0b7 and 2.0b8 !
Java is updated, (i tried both x86 and x64 , for my x64 Windows Seven) And serial doesn't run in x64 mode, and the UDP library is for 1.5.1 only, so, i can't use 2.0b x86 (i get errors)
With firmata taken from arduino 1.5.1 example, and this code on processing 1.51, it works (i only got led flickering).
import hypermedia.net.*;
Arduino arduino;
UDP udp;
  udp = new UDP( this, 56551 );
  udp.listen( true );
void draw() {;}
void receive( byte[] data, String ip, int port ) {
int intspeed = (data[12] & 0xFF)
            | ((data[13] & 0xFF) << 8)
            | ((data[14] & 0xFF) << 16)
            | ((data[15] & 0xFF) << 24);
float floatspeed = Float.intBitsToFloat(intspeed);
floatspeed = 3.6*floatspeed;
float vitesse=map(floatspeed,0,100,0,255);
int pwm=int(vitesse);
println(floatspeed);
arduino.analogWrite(9,pwm);
//reste a trovuer quelles DATA sont les bonnes
Any idea of why i cant run the very simple example , 2 posts ago ?
I've posted all my code :slight_smile:
Thanks
i got the same problem i cant get firmata working at all .been trying for ages
I plugged my Duemilanove in, opened Arduino 1.0.3, and located the AnalogFirmata sketch. I selected the correct board and correct serial port, and uploaded the AnalogFirmata sketch.
Then, I started Processing 1.5.1, and loaded the sketch in reply #2. I changed the index into the list, because my Arduino is connected to the second port in the list.
I started the Processing app running, and the TX and RX lights on the Duemilanove started flashing, and the LED on pin 3 came on very dimly, but solid.
I changed the value in the analogWrite statement in the Processing sketch, and the LED changed brightness according, with no flicker.
I'm running Win7, 64 bit, but I doubt that that matters.
From what I can tell, at least with the Duemilanove, Firmata is working just fine.
Now, It's time for you to tell us which Arduino models you are using/having issues with.
Thanks for trying this.
I tried on two different Uno R3. (one used to work with this code, on another computer)
I tried with correct values, like "COM3" , in my case. I was able to read and write digital values on ports, but i can't use analogwrite !
I agree with you, it worked on 2 other computers, Both 7 x64, so, do you think it's a problem with java or something else ?
I tried to reinstall drivers, without success.
I'm going to try on another PC (over windows 8 x64) at noon.
Thanks for your answer! :slight_smile:
With which Firmata sketch installed? There are several...
Sorry i couldn't try on another PC (i'm at work)
I tried all firmata versions (standard, pwm only , spcial for uno rev3) on all versions of arduino program (i mentioned earlier)
I'll try after work !
Thanks.
