Arduino for controlling air solenoids
Hello there! I just signed up, hope i'll have a good time here :slight_smile:
Im just a starter in arduino and just know how to make and LED blink and pretty basic stuff.. also, i'm a beginner in electronics in general(not that I'm an idiot at that, lets just say that)
Anyways.. I need an Arduino to control an "air valve block" (not the one in the picture but basically yhe same principle). I would use it on a car, to control the air suspension thats currently on it. So the arduino should read 4 sensors (one on each wheel, also pictured) that would tell it which solenoid to open, and when to close it. Also, it would need to have a feature where it automatically opens all the valves at once, to either inflate or deflate the four airbags.
I hope that someone can help me out with this, at least with a list of components to use..
Bare in mind that I know there are ready available parts that do exactly that, but I like to experiment, and also i know that someone already built one of those but he doesn't seem to be online anymore, or doesn't want to be disturbed anyways..
Thank you very much, and sorry if I misspelled something, im from Croatia. :slight_smile:
Start to studie the ready built hight/air level sensors. Don't even dream about creating Your own sensors. They will not survive any other climate than inside a garage.
Yeah... 4 inputs & 4 outputs should be "easy'.
Do you have any technical information about the sensors? Are they just switches, or maybe they have a potentiometer?
If the sensors are connected to the 12V system, you'll need a voltage divider (2-resistors) and/or a resistor-diode over-voltage circuit for each sensor because the Arduino runs at 5V.
And the valves probably aren't simply on/off, right? I'm guessing there are 3-states... Inflate, deflate, hold? That would require 8 outputs.
[u]Here is a MOSFET driver circuit[/u] for a motor or solenoid.
And... If this thing is fully-automatic and running all of the time, you'll probably have to "do something" (in software) so it's stable and not constantly re-adjusting & switching on/off (unless you want that). For example, a heating/cooling system has hysteresis (AKA "swing"). A heater switches-on slightly below the target temperature, then it stays-on until it's slightly above the target. Then after it's off again, it doesn't come-on until the temperature is slightly-below target again.
That's easy once you get your software going but you'll still need the independent sensing because they won't all inflate/deflate at the same exact rate.
Hello.. seems that I don't get notified when someone posts
