thank you for response,
Yes I can successfully each code independently.
Here code for PLC read:
#include <SPI.h>
#include <Ethernet.h>
#include "Settimino.h"
// Uncomment next line to perform small and fast data access
#define DO_IT_SMALL
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0x90, 0xA2, 0xDA, 0x0F, 0x08, 0xE11 };
IPAddress Local(192,168,1,70); // Local Address
IPAddress PLC(192,168,1,65); // PLC Address
byte Buffer[256];
S7Client Client;
unsigned long Elapsed; // To calc the execution time
// Setup : Init Ethernet and Serial port
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// Start the Ethernet Library
Ethernet.begin(mac, Local);
// Setup Time, someone said me to leave 2000 because some
// rubbish compatible boards are a bit deaf.
delay(2000);
Serial.println(Ethernet.localIP());
// Connects to the PLC
bool Connect()
int Result=Client.ConnectTo(PLC,
0, // Rack (see the doc.)
2); // Slot (see the doc.)
Serial.print("Connecting to ");Serial.println(PLC);
if (Result==0)
Serial.print("Connected ! PDU Length = ");Serial.println(Client.GetPDULength());
Serial.println("Connection error");
return Result==0;
// Dumps a buffer (a very rough routine)
void Dump(void *Buffer, int Length)
int i, cnt=0;
pbyte buf;
if (Buffer!=NULL)
buf = pbyte(Buffer);
buf = pbyte(&PDU.DATA[0]);
Serial.print("[ Dumping ");Serial.print(Length);
Serial.println(" bytes ]==========================");
for (i=0; i<Length; i++)
cnt++;
if (buf[i]<0x10)
Serial.print("0");
Serial.print(buf[i], HEX);
Serial.print(" ");
if (cnt==16)
cnt=0;
Serial.println("===============================================");
// Prints the Error number
void CheckError(int ErrNo)
Serial.print("Error No. 0x");
Serial.println(ErrNo, HEX);
// Checks if it's a Severe Error => we need to disconnect
if (ErrNo & 0x00FF)
Serial.println("SEVERE ERROR, disconnecting.");
Client.Disconnect();
// Profiling routines
void MarkTime()
Elapsed=millis();
void ShowTime()
// Calcs the time
Elapsed=millis()-Elapsed;
Serial.print("Job time (ms) : ");
Serial.println(Elapsed);
// Main Loop
int Size, Result;
void *Target;
#ifdef DO_IT_SMALL
Size=64;
Target = NULL; // Uses the internal Buffer (PDU.DATA[])
#else
Size=1024;
Target = &Buffer; // Uses a larger buffer
#endif
// Connection
while (!Client.Connected)
if (!Connect())
Serial.print("Reading ");Serial.print(Size);Serial.println(" bytes from DB1");
// Get the current tick
MarkTime();
Result=Client.ReadArea(S7AreaDB, // We are requesting DB access
1, // DB Number = 1
0, // Start from byte N.0
Size, // We need "Size" bytes
Target); // Put them into our target (Buffer or PDU)
if (Result==0)
ShowTime();
Dump(Target, Size);
CheckError(Result);
here the code for Modbus TCP:
#include <SPI.h>
#include <Ethernet.h> //for W5100
#include "Mudbus.h"
Mudbus Mb;
uint8_t mac[] = { 0x90, 0xA2, 0xDA, 0x0F, 0x08, 0xE11 };
uint8_t ip[] = { 192, 168, 1, 70 };
uint8_t gateway[] = { 192, 168, 1, 1 };
uint8_t subnet[] = { 255, 255, 255, 0 };
Ethernet.begin(mac, ip, gateway, subnet);
delay(5000); //Time to open the terminal
analogReference(EXTERNAL); //Power the sensor with the 3.3V supply and run a wire from there to the AREF pin.
#define AREF_VOLTS 3.33
Mb.Run();
Mb.R[5]++;
//Analog inputs 0-1023
Mb.R[6] = analogRead(A2); //Raw signal from sensor.
double Volts = double(Mb.R[6]) / 1023 * AREF_VOLTS;
Mb.R[7] = Volts * 1000; //Volts on A2 (x1000 to get digits to the right of the decimal).
Mb.R[8] = map(Mb.R[7], 100, 2000, -400, 1500); //Degrees C x 10
Mb.R[9] = map(Mb.R[7], 100, 2000, -400, 3020); //Degrees F x 10
Is possible the code above merged?
thank
