Arduino FreeRTOS code flip
Hello to everyone;
I have my arduino code written in my c language.I need to write FreeRTOS code that performs the same function. How should I make a conversion? Where can I find out?
#include<Servo.h>
const int sensorMin = 0; // sensor minimum
const int sensorMax = 1024; // sensor maximum
int speakerPin = 3;
Servo sg90;
 // initialize serial communication @ 9600 baud:
 pinMode (speakerPin, OUTPUT);
 sg90.attach(7);
 // read the sensor on analog A0:
 int sensorReading = analogRead(A0);
 // map the sensor range (four options):
 // ex: 'long int map(long int, long int, long int, long int, long int)'
 int range = map(sensorReading, sensorMin, sensorMax, 0, 3);
// range value:
 switch (range) {
 case 0: // A fire closer than 1.5 feet away.
 Serial.println("** Close Fire **");
 analogWrite (speakerPin, 50);
 sg90.write(180);
 case 1: // A fire between 1-3 feet away.
 Serial.println("** Distant Fire **");
 analogWrite (speakerPin, 255);
 sg90.write(0);
 delay(1); // delay between reads
You could start here.
Your task might look something like this:
void task()
    // setup all things here
    while(true)
        // this is your loop
thank you sir. but I don't have a lot of time If you know something about the subject, can you help? I don't have any priorities. Is it actually a logic used to assign freeRTOS task priorities?
Someone on the Gigs and Collaborations forum may be willing to do your work for you. You'll need to negotiate a mutually-agreeable fee for their services.
it could be a logical approach for me. I'm in a hurry about this. But I will wait a little longer if he can help me here.
I've set task1. But I have to move the buzzer and servo control I have on task 1 to task 2.
But when I carry the codes, the buzzer works continuously and doesn't move according to the data.
#include <Arduino_FreeRTOS.h>
#include <Servo.h>
int speakerPin = 3;
Servo sg90;
int range;
 sg90.attach(7);
  xTaskCreate(Task1,"Sensor", 100, NULL, 1, NULL);
  xTaskCreate(Task2,"Servo Motor", 100, NULL, 0, NULL);
void Task1(void *pvParameters)
  for(;;)
    vTaskDelay(2/portTICK_PERIOD_MS);
    vTaskDelay(10/portTICK_PERIOD_MS);
     if(range==0)
      sg90.write(180);
    if(range==1)
      analogWrite(speakerPin, 255);
      sg90.write(0);
void Task2(void *pvParameters)
  vTaskDelay(20/portTICK_PERIOD_MS);
  for(;;)
Do you need to use an RTOS at all ?
What are you trying to do ?
I would like to schedule the code with 2 pieces rtos and let the servo motor run in the second task of the buzzer.
darkdemon06:
OK, but do you need to use an RTOS ?
You seem stuck on the idea of using an RTOS without considering alternatives
A quote from somewhere
to a man with a hammer everything looks like a nail
Please explain in words what the program should do and when
According to the information received from the flame sensor program runs the buzzer. Turns the servo motor to 180 degrees. The flame sensor must operate in the first task. Servo motor and buzzer should be changed according to the information in the first task. Thanks :slight_smile:
As far as I can see from the code in reply #5 then depending on the sensor reading then either the servo is moved to to 180 or 0 and either 50 or 255 is written to the speaker pin.
What else needs to happen ?
Yes sir. I want to perform servo and buzzer operations on task 2. But when I move the codes there, the buzzer keeps singing and I don't understand what the servo does.
darkdemon06:
The requirements that I suggested in reply #10, which you seem to agree with, seem simple to achieve
start of loop()
  read the input
    if input value greater than high threshold
      write 50 to the speaker
      write 180 to the servo
    end if
    if input value less than low threshold
      write 255 to the speaker
      write 0 to the servo
    end if
end of loop()
What have I missed ?
#include <Servo.h>
int speakerPin = 3;
Servo sg90;
int range;
sg90.attach(7);
 for(;;)
 for(;;)
if(range==0)
     sg90.write(180);
   if(range==1)
     sg90.write(0);
this is the arrangement I want. But it doesn't work this way.
#include <Servo.h>
int speakerPin = 3;
Servo sg90;
int range;
  sg90.attach(7);
  if (range == 0)
    sg90.write(180);
  if (range == 1)
    sg90.write(0);
The fixation on FreeRTOS has not yet been explained.
gfvalvo:
Indeed not
Yes this method works. But I'm being asked to use tasks.
Is this for the purpose of learning about using tasks in a generally unsuitable environment or does the person doing the asking not know that there are other more suitable ways of meeting the requirement ?
Homework?
