Arduino_FreeRTOS.h file not found
there is lots of problem at the 2.0 ıde but this problem very fascinating there is also be at the Servo.h library
I think the problem is simply that the "Arduino_FreeRTOS" library is not compatible with the "Arduino Due" board you are compiling for.
But that is only a guess. We can provide you with a definite answer if you provide more information:
Full output
There is some valuable information in that "Output" panel you gave us a glimpse of in your picture of a computer monitor. But pictures of text aren't so useful even when the text is visible. You need to post text as text.
Please do this:
  1. Right click on the black "Output" pane at the bottom of the Arduino IDE 2.x window.
  2. From the context menu, click Copy All.
  3. Open a forum reply here by clicking the Reply button.
  4. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  5. Press Ctrl+V.
    This will paste the compilation output into the code block.
  6. Move the cursor outside of the code tags before you add any additional text to your reply.
  7. Click the Reply button to post the output.
Identify the library
Please tell us where you got this library from.
If you installed it using the Arduino Library Manager (Sketch > Include Library > Manage Libraries in the Arduino IDE or Libraries > Library Manager in the Arduino Web Editor) then say so and state the full name of the library.
If you downloaded it from a website, then please post a link to that website.
Using board 'arduino_due_x_dbg' from platform in folder: C:\Users\yyild\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12
Using core 'arduino' from platform in folder: C:\Users\yyild\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12
Detecting libraries used...
"C:\Users\yyild\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10607 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino Due"" "-IC:\Users\yyild\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\system/libsam" "-IC:\Users\yyild\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\system/CMSIS/CMSIS/Include/" "-IC:\Users\yyild\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\system/CMSIS/Device/ATMEL/" "-IC:\Users\yyild\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\cores\arduino" "-IC:\Users\yyild\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\variants\arduino_due_x" "C:\Users\yyild\AppData\Local\Temp\arduino-sketch-C9F964F74BD577E9DA0253D18DE7E829\sketch\Blink_AnalogRead.ino.cpp" -o nul
Alternatives for Arduino_FreeRTOS.h: [FreeRTOS-10.4.6-1@10.4.6-1 Arduino_FreeRTOS_Library-master@10.4.6-1 FreeRTOS@10.4.6-0]
ResolveLibrary(Arduino_FreeRTOS.h)
-> candidates: [FreeRTOS-10.4.6-1@10.4.6-1 Arduino_FreeRTOS_Library-master@10.4.6-1 FreeRTOS@10.4.6-0]
"C:\Users\yyild\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10607 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino Due"" "-IC:\Users\yyild\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\system/libsam" "-IC:\Users\yyild\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\system/CMSIS/CMSIS/Include/" "-IC:\Users\yyild\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\system/CMSIS/Device/ATMEL/" "-IC:\Users\yyild\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\cores\arduino" "-IC:\Users\yyild\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.12\variants\arduino_due_x" "-Ic:\Users\yyild\Documents\Arduino\libraries\Arduino_FreeRTOS_Library-master\src" "C:\Users\yyild\AppData\Local\Temp\arduino-sketch-C9F964F74BD577E9DA0253D18DE7E829\sketch\Blink_AnalogRead.ino.cpp" -o nul
Alternatives for avr/io.h: []
ResolveLibrary(avr/io.h)
In file included from c:\Users\yyild\Documents\Arduino\libraries\Arduino_FreeRTOS_Library-master\src/Arduino_FreeRTOS.h:59:0,
from C:\Users\yyild\AppData\Local\Temp.arduinoIDE-unsaved2022212-16720-1stsc8n.55e2\Blink_AnalogRead\Blink_AnalogRead.ino:1:
c:\Users\yyild\Documents\Arduino\libraries\Arduino_FreeRTOS_Library-master\src/FreeRTOSConfig.h:32:20: fatal error: avr/io.h: No such file or directory
#include <avr/io.h>
compilation terminated.
-> candidates: []
Multiple libraries were found for "Arduino_FreeRTOS.h"
Used: C:\Users\yyild\Documents\Arduino\libraries\Arduino_FreeRTOS_Library-master
Not used: C:\Users\yyild\Documents\Arduino\libraries\FreeRTOS-10.4.6-1
Using library Arduino_FreeRTOS_Library-master at version 10.4.6-1 in folder: C:\Users\yyild\Documents\Arduino\libraries\Arduino_FreeRTOS_Library-master
Compilation error: exit status 1
that my output panel ,show the error at the line 1 by the arduino ide 2.0 but same code working the arduino ide 1.8 version I am using the same RTOS library both ide but ide 2.0 give the error in this shape `
Önceden biçimlendirilmiş yazı
#include <Arduino_FreeRTOS.h>
// define two tasks for Blink & AnalogRead
void TaskBlink( void *pvParameters );
void TaskAnalogRead( void *pvParameters );
// the setup function runs once when you press reset or power the board
// initialize serial communication at 9600 bits per second:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB, on LEONARDO, MICRO, YUN, and other 32u4 based boards.
// Now set up two tasks to run independently.
xTaskCreate(
TaskBlink
,  "Blink"   // A name just for humans
,  128  // This stack size can be checked & adjusted by reading the Stack Highwater
,  NULL
,  2  // Priority, with 3 (configMAX_PRIORITIES - 1) being the highest, and 0 being the lowest.
,  NULL );
xTaskCreate(
TaskAnalogRead
,  "AnalogRead"
,  128  // Stack size
,  NULL
,  1  // Priority
,  NULL );
// Now the task scheduler, which takes over control of scheduling individual tasks, is automatically started.
// Empty. Things are done in Tasks.
/---------------------- Tasks ---------------------/
void TaskBlink(void *pvParameters) // This is a task.
(void) pvParameters;
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, LEONARDO, MEGA, and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN takes care
of use the correct LED pin whatever is the board used.
The MICRO does not have a LED_BUILTIN available. For the MICRO board please substitute
the LED_BUILTIN definition with either LED_BUILTIN_RX or LED_BUILTIN_TX.
e.g. pinMode(LED_BUILTIN_RX, OUTPUT); etc.
If you want to know what pin the on-board LED is connected to on your Arduino model, check
the Technical Specs of your board at https://www.arduino.cc/en/Main/Products
This example code is in the public domain.
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
// initialize digital LED_BUILTIN on pin 13 as an output.
pinMode(LED_BUILTIN, OUTPUT);
for (;:wink: // A Task shall never return or exit.
digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
vTaskDelay( 1000 / portTICK_PERIOD_MS ); // wait for one second
digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
void TaskAnalogRead(void *pvParameters) // This is a task.
AnalogReadSerial
Reads an analog input on pin 0, prints the result to the serial monitor.
Graphical representation is available using serial plotter (Tools > Serial Plotter menu)
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
for (;:wink:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// print out the value you read:
Serial.println(sensorValue);
vTaskDelay(1);  // one tick delay (15ms) in between reads for stability
that my example code this code example code in the rtos library
}Önceden biçimlendirilmiş yazı
OK, this is valuable information.
I'm going to ask you to provide the verbose output from compiling the same sketch using Arduino IDE 1.8.
Please do this:
  1. Start Arduino IDE 1.8
  2. Select File > Preferences from the Arduino IDE menus.
  3. Check the box next to "Show verbose output during: ☐ compilation".
  4. Click the OK button.
  5. Select Sketch > Verify/Compile from the Arduino IDE menus.
  6. Wait for the compilation to finish.
  7. Click on the black console pane at the bottom of the Arduino IDE window.
  8. Press Ctrl+A to select all the text.
  9. Press Ctrl+C.
    This will copy the selected text to the clipboard.
  10. Open a forum reply here by clicking the Reply button.
  11. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the compilation output is correctly formatted.
  12. Press Ctrl+V.
  13. Move the cursor outside of the code tags before you add any additional text to your reply.
  14. Click the Reply button to post the output.
