Hello,
I'm working on a project for a paludarium, it will be in charge of keeping the plants watered and making sure that thei get the right colours of light throughout the day using rgb +cct leds.
for this i use a arduino uno r3 as the brains, a driver for the watering pump, some mosfets to drive the leds and a few !2C devices, thats where the problem comes in
I use 3 devices that communicate with the arduino over I2C, a DS3234 real time module, a polulu I2C lcd adaptor, and the adafruit pca9685 16 channel 12 bit servo driver (which i use to have some more pwm pins to work with), all of them on breakout boards.
I was setting up a test to get a hang of working with the pca9685, so i made a sketch that reads a rotary encoder and use that input to controll a dc motor, the enable pins on the motor driver are wired directly to the arduino (pins 7 and 12 as defined in the code below) and the pwm input of that driver to pwm pin 0 on the pca9685, so i uploaded the code and tested just with the rotary encoder to see if everything worked as intended, you know, just putting some serial feedback here and there in the code , and it did work, so i disconnected the usb and hooked up the power-supply, everything powered up, hit the button on the encoder, and you guess it, nothing....
Long story short, the arduino completely grinds to a halt when any of the 3 I2C devices gets connected, it doesnt execute any of the code, there is no more serial communication, nothing, with any of the i2c devices connected, and as soon as you disconnect them, it starts working again :o .
i have no idea what could be the problem, the only thing i can really think of is that it has to do with my wiring, i'm kind of making my own shield for the uno in this proyect, using header pins on a prototyping pcb, so maybe the added wires and solder joints going to the cconnectors for the I2C devices messes with it, no idea, i hope someone can help me shed som light on this one
thanks in advance and greetings, Nook
this is my test code:
#include <Adafruit_PWMServoDriver.h>
#include <Wire.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// you can also call it with a different address and I2C interface
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(&Wire, 0x40);
#define floater_btn 8;
#define in_a 7
#define in_b 12
#define pwmnum 0
#define enc_a 2
#define enc_b 3
#define enc_c 8
volatile byte enc_status, enc_dir, enc_but, last_enc;
byte buttons_status;
byte motor_status = 0;
byte motor_dir = 0;
unsigned int pwms = 0;
byte dir;
 pwm.begin();
 pwm.setPWMFreq(500);
Â
 pinMode(enc_a, INPUT_PULLUP); pinMode(enc_b, INPUT_PULLUP); pinMode(enc_c, INPUT_PULLUP);
 //pinMode(pwm_pin, OUTPUT);
 pinMode(in_a, OUTPUT);
 pinMode(in_b, OUTPUT);
 delay(100);
 motor_status = 0;
attachInterrupt(digitalPinToInterrupt(enc_a), read_enc, CHANGE);
 attachInterrupt(digitalPinToInterrupt(enc_b), read_enc, CHANGE);
if (enc_dir == 1){
 enc_dir = 0;
 if (motor_status == 1){
 motor_dir = 0;
 Serial.println("direction 1");
 } else if (motor_status == 0){
  if(pwms >= 255){
   pwms = 255;
  pwms ++;
  motor_controll();
  Serial.println("pwm:");
Serial.println(pwms);
if(enc_dir == 2){
 enc_dir = 0;
 if(motor_status == 1){
 motor_dir = 1;
 Serial.println("direction 2");
  pwms --;
  motor_controll();
Â
 Â
   if(enc_but == 128){
  motor_controll();
  delay(900);
 read_but();
 if(motor_status == 0){
  if(enc_but == 128){
  digitalWrite(in_a, LOW);
  digitalWrite(in_b, LOW);
  pwm.setPWM(pwmnum, 0, 4096);
  pwms = 255;
  motor_status = 1;
  Serial.println("stop");
  delay(900);
  read_but();
/*Serial.println(motor_status);
Serial.println(enc_dir);
Serial.println("button stat");
Serial.println(enc_but);*/
read_but();
read_enc();
void motor_controll()
 if (motor_dir == 0){
  digitalWrite(in_a, HIGH);
  pwm.setPWM(pwmnum, 0, (pwms * 16));
 } else if (motor_dir == 1){
  digitalWrite(in_b, HIGH);
 motor_status = 0;
 Serial.println("start");
Â
void read_but()
 bool pin_status;
 delay(3);
 pin_status=digitalRead(enc_c);
 if(pin_status == LOW && enc_but !=128) {enc_but = 128;}
 if(pin_status == HIGH && enc_but ==128){enc_but=1;}
void read_enc()
 //returns 0 if nothing is set
 //returns 1 if A is set but B is not
 byte a=0;
 delayMicroseconds(200);
 if(digitalRead(enc_a) == HIGH ){a=B01;}
 if(digitalRead(enc_b) == HIGH ){a=a+2;} //set the second bit
 if(last_enc!=a)
  last_enc = a;
  enc_status = enc_status*4;
  enc_status = enc_status + a;
  //Serial.print(enc_status, DEC);Serial.print("/");Serial.print(a, DEC);Serial.print(" ");
  switch(enc_status)
   case 0x4b:enc_dir=1;enc_status=0;break; //ccw, enc_dir=1
   case 0x87:enc_dir=2;enc_status=0;break; //cw enc_dir=2
   default : enc_dir =0;break;
