A common way to do this is to use an interrupt. Just detect a rising edge and increment a count. Once in a while using millis for timing, calculate the frequency and zero the count. Don't forget to make the count variable volatile.
wildbill:
Like this??
The IR pin output is 4.75V when no object is detected and 0 when object is detected. Hence I've taken falling edge. Will this code work?? (taken directly from a website)
int ir_pin=2;
float count=0;
int rpm;
int oldtime=0;
int _time;
void RPM()
count++;
pinMode(ir_pin,INPUT);
attachInterrupt(0,RPM,FALLING);
detachInterrupt(0);
_time=millis()-oldtime;
rpm=(count/_time)*60000;
oldtime=millis();
count=0;
Serial.println(rpm);
That's a crude version of the method, yes. Try it.
Note that you may get integer division effects here:
But it should get you started.
Why is count a float?
Why isn't it qualified as volatile?
kzkhan98:
Like this??
Please read how to use 'code tags' to post code. there are instructions in one of the sticky links at the top of every forum.
also, when referencing a website, it really helps to post a link to that website.
I took only part of your code and added comments.
this part ;
calls the void RPM() function to allow count to increment
void RPM()
count++; // increments count when called from the interrupt
detachInterrupt(0); // stops interrupt while doing the math and printing
rpm=(count/_time)*60000; // calculates RPM
oldtime=millis();
count=0; // re-zeros the count use in rpm() after math is done
attachInterrupt(0,RPM,FALLING); // allows the interrupt to start incrementing
wildbill:
count needs to be set as an int or long ?
if you do not assign a value the very first reading, and only the very first reading on startup will be off, for one second. if you are concerned, make it =0 in startup()
int ir_pin=2;
// float count=0;
int count ; // need to create this variable before using it.
int rpm;
int oldtime=0;
int _time;
void RPM()
count++;
