Arduino Game, adding scoring system?
Hello guys, thanks to some help I'v managed to get somewhat of a game working and now I'm trying to implement a scoring system that adds points until the user fails which then will display the total score on serial monitor. I'm trying to think of a scoring system but I'm not sure how, can anyone help me put a scoring system in this code? if so thank you very much
I'v been trying to work on this for awhile and my idea is this:
State score(){
  if (pressed = correct;)
  Serial.println("Score = +10");(
This is what my game code looks like:
#include <SM.h>
SM game(gameStart);
const int noControls = 4;
const byte led[noControls] = {9, 10, 11, 12};
const byte btn[noControls] = {2, 3, 5, 7};//pin 0 and 1 are for serial
const byte startBtn = 6;
const unsigned long limit = 120;//reaction time limit
byte currentCtrl;
enum btnState {noPress, correct, fault};
void setup(){
  for(byte i = 0; i<noControls; i++) pinMode(led[i], OUTPUT);
  randomSeed(analogRead(0));
}//setup()
void loop(){
  EXEC(game);
}//loop()
State gameStart(){
  if (not)(!digitalRead(startBtn)){
    currentCtrl = random(noControls);//determine control number
    ledCtrl(1<<currentCtrl);//light correct led
    Serial.print("Started with:");
    Serial.println(currentCtrl);
    game.Set(randomLed);//change state
  }//if(stertBtn)
  for(byte i = 0; i<noControls; i++) if(!digitalRead(btn[i])){//check if user cheats
    ledCtrl(15);//all leds on
    Serial.println("Cheat!");
    game.Set(miss);//change state
    break;//no need to check further
  }//if(cheat)
}//gameStart()
State randomLed(){
//  if(game.Timeout(limit)){//check for Timeout
//    ledCtrl(15);//all leds on
//    Serial.println("Timeout");
//    game.Set(miss);//change state
//  }//if(Timeout)
  btnState pressed = noPress;
  for(byte i = 0; i<noControls; i++){//scan all buttons
    if(!digitalRead(btn[i])){//check individual button
      if(i == currentCtrl){//check validity of btn
        pressed = correct;//we have a hit
      }else{//incorrect btn
        pressed = fault;//false press
        break;//abort scan
    }//if(btn[i])
  }//for(i)
  switch(pressed){//act on press
    case correct:
      currentCtrl = 1;//reuse currentCtrl for display
      ledCtrl(currentCtrl);
      Serial.println("Hit");
      game.Set(success);//change state
      break;//case correct
    case fault:
      Serial.println("Wrong button");
      break;//case fault
  }//switch(pressed)
}//randomLed()
State miss(){
  if(game.Timeout(1000)){
    ledCtrl(0);//all leds off
    Serial.println("Back to start from miss");
    game.Set(gameStart);
}//miss()
State success(){
  if(game.Timeout(300)){//wait 300ms
    currentCtrl <<= 1;//shift 1 bit
      if(currentCtrl<(1<<noControls)){//more ledsd to show?
        game.Set(success);
      }else{//back to start
        Serial.println("back to start from success");
        game.Set(gameStart);//change state
  }//if(wait 300 ms)()
}//success()
inline void ledCtrl(byte ctrl){
  for(byte i = 0; i<noControls; i++) digitalWrite(led[i], !!(ctrl&(1<<i)));
}//ledCtrl()
If you successfully assign correct to pressed, do something. Hmmm, seems strange.
I do not understand the following statements, please explain:
  if (not)(!digitalRead(startBtn)) {
  // more code...
  // More code...
    digitalWrite(led[i], !!(ctrl & (1 << i)));
econjack:
// more code...
// More code...
The buttons were opposite which is the reason for (not), else it does the samething as Digitalread(HIGH) but detects if the start button is pressed.
Also the game works okay, except for the timer.
No, I was asking about the statement:
The syntax for an if expression is:
if (expression1) {
but your statement places a parenthesized (not) before expression1. That draws a compile error on my machine. Are you saying it compiles on yours?
It works fine on mine, sorry I forgot to say I was using STML with the arduino. (!digitalRead(startBtn)) I know it's suppose to be if(expression) but it was reading the buttons the wrong way so to make it read negative a (not) was put to reverse it.
Anyway can anyone help me add a scoring system with this game plz? :c
