Arduino Game Board - Q/A
Just to show that you can remap the Question switches to different Answer switches.
In this version, pushing a switch connected on pin 8, remaps the Q and As as in the arrays below:
//original question and answer associations
//           Question switches  2  4  6  22  24  26  28  30  32  34  36  38
byte originalAnswers[12]     = {3, 5, 7, 23, 25, 27, 29, 31, 33, 35, 37, 39};
//remapped question and answer associations
byte remappedAnswers[12]     = {7, 3, 5, 39, 37, 35, 33, 31, 29, 27, 25, 23};
Sketch version 1.08 (with remapping option)
// https://forum.arduino.cc/t/arduino-game-board-q-a/927329
// Version   YY/MM/DD   Description
// 1.00      21 11 20   Working sketch
// 1.02      21 11 20   Added a Structure definition so we can easily have 12 QandAs
// 1.03      21 11 20   Needs additions and testing for 12 switches
// 1.04      21 11 21   Combined some tests; added some comments
// 1.05      21 11 21   Added trapping for more than 2 switches pressed;
//                      added heartbeat LED and buzzer
// 1.06      21 11 21   Move the switches to different controller pins
// 1.07      21 11 27   To speed up execution time, added switchChangeFlag
// 1.08      21 11 28   Option to remap the question switches to different answer switches
// Matching a question to the correct answer turns on the "Correct Green LED"
// Matching a question to the wrong answer turns on the "Wrong Red LED"
//if the next line is commented, NO debug code is generated
//#define DEBUG
#ifdef DEBUG
//                                for oscilloscope triggering
#define PULSE9                    cli(); PINB = bit(PINB1); PINB = bit(PINB1); sei()
#else
#define PULSE9                    //nothing defined
#endif
//5V---[Internal 50k Resistor]---Pin---[Switch]---GND
#define PUSHED                    LOW
//Pin---[220R]---[A->|-K]---GND
#define LEDon                     HIGH
#define LEDoff                    LOW
#define ENABLED                   true
#define DISABLED                  false
//const byte buzzer               = 12;
//const byte heartbeatLED         = 13;
//const byte GreenLED             = 11;       //Correct Answer LED
//const byte RedLED               = 10;       //Wrong Answer LED
const byte remapSwitch          = 8;
#ifdef DEBUG
const byte pulsePin             = 9;      //pin PINB1, for oscilloscope triggering
#endif
const byte buzzer               = 50;
const byte heartbeatLED         = 51;
const byte GreenLED             = 52;       //Correct Answer LED
const byte RedLED               = 53;       //Wrong Answer LED
bool switchChangeFlag           = DISABLED;
byte RedLEDflag;
byte GreenLEDFlag;
byte switchCount;
byte currentState;
byte lastRemapSwitch            = !PUSHED;
//define the Question and Answer Structure
struct QandA
  const byte Qpin;
  byte       Apin;
  byte       bitNumQ;
  byte       bitNumA;
  byte       lastStateQ;
  byte       lastStateA;
}; //END of struct QandA
//the number of QandA pairs to be defined
const byte numQuestions         = 12;
//define all the objects
QandA pairNum[numQuestions]     =
  // pins    bits   last Q   last A
  //Q   A   Q   A
  { 2,  3,  0,  1, !PUSHED, !PUSHED},    //pair #1     Qpin Apin bitNumQ bitNumA lastStateQ lastStateA
  { 4,  5,  2,  3, !PUSHED, !PUSHED},    //pair #2
  { 6,  7,  4,  5, !PUSHED, !PUSHED},    //pair #3
  {22, 23,  6,  7, !PUSHED, !PUSHED},    //pair #4
  {24, 25,  8,  9, !PUSHED, !PUSHED},    //pair #5
  {26, 27, 10, 11, !PUSHED, !PUSHED},    //pair #6
  {28, 29, 12, 13, !PUSHED, !PUSHED},    //pair #7
  {30, 31, 14, 15, !PUSHED, !PUSHED},    //pair #8
  {32, 33, 16, 17, !PUSHED, !PUSHED},    //pair #9
  {34, 35, 18, 19, !PUSHED, !PUSHED},    //pair #10
  {36, 37, 20, 21, !PUSHED, !PUSHED},    //pair #11
  {38, 39, 22, 23, !PUSHED, !PUSHED}     //pair #12
//END of our Structure and definition
//The flag is 32 bits, corresponds to 16 question/answer pairs
//A=Answer, Q=Question           AQAQAQAQAQAQAQAQAQAQAQAQAQAQAQAQ
//Q and A number                 11111111111111
//                               66554433221100998877665544332211
//Bit                            3322222222221111111111
//Number                         10987654321098765432109876543210
unsigned long Flag           = 0b00000000000000000000000000000000;  //32 bits
//question switch pushed
unsigned long question[12]   = {1, 4, 16, 64,  256, 1024, 4096, 16384,  65536, 262144, 1048576, 4194304};
//element #                     0  1   2   3     4     5     6      7       8       9       10       11
//answer switch pushed
unsigned long answer[12]     = {2, 8, 32, 128, 512, 2048, 8192, 32768, 131072, 524288, 2097152, 8388608};
//timing stuff
unsigned long switchMillis;
unsigned long heartbeatMillis;
  pinMode(buzzer, OUTPUT);
  pinMode(heartbeatLED, OUTPUT);
  pinMode(GreenLED, OUTPUT);
  pinMode(RedLED, OUTPUT);
#ifdef DEBUG
  pinMode(pulsePin , OUTPUT);
  digitalWrite(pulsePin, LOW);
#endif
  for (byte x = 0; x < numQuestions; x++)
    pinMode(pairNum[x].Qpin, INPUT_PULLUP);
    pinMode(pairNum[x].Apin, INPUT_PULLUP);
  pinMode(remapSwitch, INPUT_PULLUP);
} //END of setup()
  //time to toggle the heartbeat LED ?
  if (millis() - heartbeatMillis >= 500)
    //restart the TIMER
    heartbeatMillis = millis();
    //toggle LED
    digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
  //is it time to check the switches ?
  if (millis() - switchMillis >= 50)
    //restart the TIMER
    switchMillis = millis();
    checkSwitches();
  //has there been a state change in any of the switches ?
  if (switchChangeFlag == ENABLED)
    //yes, okay, we will deal with it
    controlLEDs();
  //other none blocking code goes here
} //END of loop()
void controlLEDs()
  //control the LEDs as per switches pushed
  //initialize
  RedLEDflag = LEDon;
  //more than 2 switches pressed ?
  if (switchCount > 2)
    GreenLEDFlag = LEDoff;
  //no switches are pushed ?
  else if (Flag == 0)
    RedLEDflag = LEDoff;
    //check what switches are being pushed
    for (byte x = 0; x < 12; x++)
      //for oscilloscope triggering
      PULSE9;
      //are the correct switches are pushed ?
      if (Flag == question[x] + answer[x])
        GreenLEDFlag = LEDon;
        //we found them, no need to go further
      //is 1 question switch is pushed ?
      else if (Flag == question[x])
        //we found it, no need to go further
      //is 1 answer switch is pushed ?
      else if (Flag == answer[x])
    } //END of for (byte x = 0; x < 12; x++)
  } //END of else()
  //update the LEDs and sound the buzzer as needed
  digitalWrite(GreenLED, GreenLEDFlag);
  digitalWrite(RedLED, RedLEDflag);
  //correct buzzer sound
  if (GreenLEDFlag == LEDon)
    tone(buzzer, 4000, 500);
  //wrong buzzer sound
  else if (RedLEDflag == LEDon)
    tone(buzzer, 500, 500);
} //END of  controlLEDs()
void checkSwitches()
  //scan all the switches to see if there are changes in state, act accordingly
    //current                                        Q u e s t i o n   s w i t c h
    currentState = digitalRead(pairNum[x].Qpin);
    //was there a change in state ?
    if (pairNum[x].lastStateQ != currentState)
      //update to the new state
      pairNum[x].lastStateQ = currentState;
      //a switch has changed state, Flag it
      switchChangeFlag = ENABLED;
      //was the switch PUSHED ?
      if (currentState == PUSHED)
        switchCount++;
        //set the associated flag bit
        Flag = Flag | bit(pairNum[x].bitNumQ);
      //the switch was released
        switchCount--;
        //reset the associated flag bit
        Flag = Flag & ~bit(pairNum[x].bitNumQ);
      //print the Flag so we can see the total
      Serial.print(Flag);
      //print the number of switches being pressed
      Serial.print("\t Switches pressed = ");
      Serial.println(switchCount);
    } //END of  if (pairNum[x].lastStateQ != state)
    //current                                        A n s w e r   s w i t c h
    currentState = digitalRead(pairNum[x].Apin);
    if (pairNum[x].lastStateA != currentState)
      pairNum[x].lastStateA = currentState;
        switchCount++;
        Flag = Flag | bit(pairNum[x].bitNumA);
        switchCount--;
        Flag = Flag & ~bit(pairNum[x].bitNumA);
      Serial.print(Flag);
    } //END of  if (pairNum[x].lastStateA != state)
  } //END of  for (byte x = 0; x < numQuestions; x++)
  //                                               r e m a p S w i t c h
  currentState = digitalRead(remapSwitch);
  if (lastRemapSwitch != currentState)
    lastRemapSwitch = currentState;
      //the question switches are remapped to new answer switches
        pairNum[x].Apin = remappedAnswers[x];
      Serial.println("\nQuestion switches have been remapped.\n");
} //END of checkSwitches()
