Hi Maam/Sir!, I am newby to Arduino i just want to ask question for my thesis. Our thesis title is Air Quality monitoring system using arduino. Is there any way to separate air pollutants data that detects by the sensor ?. just like my example below. Thank you for Answering and Thankyou in advance This will be a big help for us.
Kimarin0:
I'm sorry for that sir. My question is, is there any code for that on any kind of gas sensors that can be separate all the collected data.
Impossible to say without more detail. But let's suppose you're going to go the conventional route and get some MQ series sensors such as the MQ-7 for measuring CO. When wired appropriately, it gives you an analog voltage that, with calibration, will give you an indication of CO levels although temperature and humidity impact the reading too.
But now you've got a single voltage - there is no way to subdivide that into the different gasses you're looking for.
Worse still, just because the sensor is affected by CO, doesn't mean that other gases don't have an effect. So not only can you not distinguish between gasses using such a sensor, you're not even really sure that you're measuring CO - could be one of several others.
As i have searched, there are gases that can sense multiple air pollutants. but according to the answers for my question. there is no way to separate the data for the different pollutants that has been collected by the sensor. And this is our concern for this Topic.
The MQ sensors are not exactly specific. There may be more specific ones out there. Or combine a number of sensors as done in the "electronic nose" project (don't have the link at hand - do a Google search).
Hello Ma'am/Sir,
I have a question. If we are using sensor to detect many gases such as MQ135 and etc, then how we will know their percentage level SEPARATELY ??
