Arduino Gearshift indicator
This is a gear shift indicator for vehicles using an arduino nano and seven segments led
you can improve these prototype and integrated on the dash board
[code]
int a=6;
int b= 7;
int c= 8;
int d=9;
int e=10;
int f=11;
int g=12;
#define gear1 A6
#define gear2 A7
#define gear3 5
#define gear4 4
#define gear5 2
#define rever 3
  pinMode(gear1,INPUT);
  pinMode(gear2,INPUT);
  pinMode(gear4,INPUT);
  pinMode(gear5,INPUT);
  pinMode(rever,INPUT);
 pinMode(a,OUTPUT);
 pinMode(b,OUTPUT);
 pinMode(c,OUTPUT);
 pinMode(d,OUTPUT);
 pinMode(e,OUTPUT);
 pinMode(f,OUTPUT);
 pinMode(g,OUTPUT);
int g1 =analogRead(gear1);
int g2 =analogRead(gear2);
int g3= digitalRead(gear3);
int g4= digitalRead(gear4);
int g5= digitalRead(gear5);
int r= digitalRead(rever);
 if (g1<100)
 {limpia();
    primera();}
 else if (g2<100)
    {limpia();
    segunda();}
else if (g3==LOW)
  {limpia();
    tercera();}
 else if  (g4==LOW)
  {limpia();
    cuarta();}
    else if (g5==LOW)
  {limpia();
    quinta();}
       else if (r==LOW)
  {limpia();
    reversa();}
  else {limpia();
  neutral();
  //delay(10);
void neutral(){
 digitalWrite(c,HIGH);
 digitalWrite(e,HIGH);
 digitalWrite(g,HIGH);
  void reversa(){
 digitalWrite(c,LOW);
  void primera(){
 digitalWrite(b,HIGH);
  void segunda(){
 digitalWrite(a,HIGH);
 digitalWrite(d,HIGH);
  void tercera(){
  void cuarta(){
 digitalWrite(f,HIGH);
  void quinta(){
  void limpia(){
 digitalWrite(a,LOW);
 digitalWrite(b,LOW);
 digitalWrite(d,LOW);
 digitalWrite(e,LOW);
 digitalWrite(f,LOW);
 digitalWrite(g,LOW);
[/code]
A bit more information, are these passenger type of vehicles or models. My SWAG is model because production cars do not use Arduinos and the selectors are different.
Esquema-gearshift.pdf (34,8 KB)
This is the prototype: Redirecting...
Nice Job on the schematic.
Hi, @luis_vs schematic
Does the brightness of the segments change as the digits displayed change?
Tom... :grinning: :+1: :coffee: :australia:
yes since it is a prototype, but you can add a resistor for each segment to avoid this
Hello @luis_vs, can you please share the prototype again??
Can't view it on facebook.
hello the link is working fine
