Just got a new idea for a project during our tropical storm after the power went out. What if i had an arduino do everything i just did? Flip main breaker off, turn on the generator, make sure it was running, and gradually connect and turn on individual circuits. I've been running though a scheme of attack for the past hour and it seems possible.
I would think i would need:
arduino mega
reset-able fuse for each circuit
Project enclosures for both inside and outsite by the generator
remote transmission method, wireless (x bee) or wired. (may be even use the existing wire going to the outside power box)
miscellaneous buttons and switches.
arduino backup battery (12V, like the apc back up batteries)
multiple 5v relays to switch over 120v/240v relays
some other stuff i haven't thought of.
The plan of attack is to mount radioshack project boxes (the large ones) on the interior wall and outside with a 16 x 2 lcd. it would constantly monitor the voltage level of the mains power supply. when the power level drops then it would kick over into a standby mode and beep every second power is off. after ten seconds it would send a command to the outside station and start the generator. after the signal level of the output is consistent (to some degree) it would then begin to activate switches to pull off mains to the generated power. and continue to monitor the mains power supply. when it comes back on, it will wait thirty seconds then begin to one by one switch over back to mains. waits another thirty seconds (just in case) and begins to shutdown the generator.
Anyone else ever thought of this? Ideas? incite? all is appreciated. Yes, i am using this as a blog of some sort
