Arduino/Genuino 101 CurieIMU Orientation Visualiser
I cannot get this to run. I changed the port in the Processing code to the port the 101 is using with no success. The preocessing sketch is unsuccessful.
Help
I read the Genuino post which did not help me (unfortunaty). My Arduino is on COM3 so I inserted a 3 in the "myPort = new Serial(this, Serial.list()[2], 9600);" where the 2 is. When I run the Processing sketch that line is highlighted and I get the message "ArrayIndexOutOfBoundsException:3". hat am I missing?
mine genuino101 is connected to the port com4 and after a few test runs with this setting:
myPort = new Serial(this, Serial.list()[1], 9600);
I did not understand why it works
The Arduino finally worked using 0 (zero) for the port number. Maybe that makes sense to someone, but not me.
I am really new to Processing. After reading about Serial I think I finally figured out what is going on (sort of). If you know the port that the Arduino (Genuino) is using put that port in parens in place of ""Serial.list()[3]". In my case the port is COM3 so substitute "COM3". I'm sure everyone else had figured this out, but not me the newbie.
After further investigation I found that if you run
import processing.serial.*;
// The serial port Serial myPort;
// List all the available serial ports printArray(Serial.list());
it wil l return a number followed by a COM port ie. 1 COM6
The number is what you enter between the square brackets in "myPort = new Serial(this, Serial.list()[2]," in this case instead of the 2. This works or the method from my previous post.
