Arduino/Genuino Uno Uploadng Problem
I am new to Arduino since i just started using! for Mechatronics course. The problem is, whenever i try to upload a code like “blink” example code i am getting an error but code compiles just fine. I tried changing the versions of IDE but it didn’t work. I searched for a solution but couldn’t find a working one. Port and board selection is correct. I am using Ubuntu 16.10. The error message, the system and board information is as below. Any help would be appreciated.
Linux Kernel Info:
Linux Gangie 4.8.0-44-generic #47-Ubuntu SMP Wed Mar 22 14:27:57 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Board info:
BN: Arduino/Genuino Uno
VID: 2341
PID: 0043
SN: 754333137393518060C0
Error message:
Sketch uses 1,066 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: verification error, first mismatch at byte 0x0002
         0x68 != 0x5c
avrdude: verification error; content mismatch
Not sure what your problem could be but if you go into the IDE File-> Preferences and you enable "verbose output during programming" you will get more details as to what is happening during uploading.
Franck
Thank you for responding. I did what you said. Here is the output for compilation and uploading. I used 1.6.9 Arduino IDE and AVR ISP, AVRISP mkII, ArduinoISP, Arduino as ISP programmer is used. All of them gave the same error.
for compiling there is a text file in the attachments since 9000 character limit in the forum.
For uploading:
/home/mtaskin/Documents/arduino-1.6.9/hardware/tools/avr/bin/avrdude -C/home/mtaskin/Documents/arduino-1.6.9/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyACM0 -b115200 -D -Uflash:w:/tmp/builde5a2dea7b37df114b46bdb3dc5b914d6.tmp/Blink.ino.hex:i
avrdude: Version 6.0.1, compiled on Apr 14 2015 at 19:04:16
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/home/mtaskin/Documents/arduino-1.6.9/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/home/mtaskin/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: reading input file "/tmp/builde5a2dea7b37df114b46bdb3dc5b914d6.tmp/Blink.ino.hex"
avrdude: writing flash (1066 bytes):
Writing | ################################################## | 100% 0.15s
avrdude: 1066 bytes of flash written
avrdude: verifying flash memory against /tmp/builde5a2dea7b37df114b46bdb3dc5b914d6.tmp/Blink.ino.hex:
avrdude: load data flash data from input file /tmp/builde5a2dea7b37df114b46bdb3dc5b914d6.tmp/Blink.ino.hex:
avrdude: input file /tmp/builde5a2dea7b37df114b46bdb3dc5b914d6.tmp/Blink.ino.hex contains 1066 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.15s
avrdude: verifying ...
         0x68 != 0x5c
avrdude done.  Thank you.
compiler.txt (12.5 KB)
So:
  • I am a newbie so hopefully someone with more experience will have good suggestions
  • I have used the same setup as you have (sticked with -c arduino though), and got the same error at the same stage, and despite the error the sketch was working fine on the target board afterwards, but...
  • ... I have also bricked two pro minis trying to program them through ArduinoISP
Personnally I ordered a dedicated small ISP programmer. Franck
hey there I have a similar problem and this is my first time using the arduino and I'm having trouble to upload it. this is the code
Man, that mismatch at 0x0002 seems to be hitting a lot of people lately, and it makes zero sense (and prior to like a month or two ago, nobody was reporting that). Something is up...
ERROR MSG:
avrdude: ser_open(): can’t open device “/dev/ttyACM0”: Permission denied
Not able to upload programs to the Arduino UNO.
Im using the 1.8.1 IDE on 32bit Ubuntu Mate 16.10 LTS.
I am able to select the port on Tools → Ports but the IDE wont upload to the board, even simple LED blinking program dosent upload.
Please help.
Hi
Have you installed the required extensions i also faced the same error when i was a newbie check the recommend or update able extensions you installed for arduino
I am a experienced and i faced this is my new computer in which i was trying to make a PS5 using arduino leonardo and i am using the arduino 2.0 so be careful with your version
I don’t know if this was helpful so yea lets get going
