#include "Ultrasonic.h"
#include <math.h>
#include <Wire.h>
#include "rgb_lcd.h"
#include <Ethernet.h>
#include <PubSubClient.h>
#if defined(ARDUINO_ARCH_AVR)
#define debug Serial
#elif defined(ARDUINO_ARCH_SAMD) || defined(ARDUINO_ARCH_SAM)
#define debug SerialUSB
#else
#endif
//server
byte mac[] = { 0xA8, 0x61, 0x0A, 0xAE, 0x2E, 0x03 }; //pls change to your arduino MAC, refer to the sticker on the side
IPAddress server(192, 168, 10, 122); //change to the php server ip
EthernetClient client;
//preset if statement
int reading = LOW;
int state = HIGH;
int previous = LOW;
int buttonPin = 6;
int stateTime = 0;
int debounce = 100;
//ultrasonic ranger
Ultrasonic ultrasonic(7);
//temperature sensor
const int B = 4275; // B value of the thermistor
const long R0 = 100000; // R0 = 100k
const int pinTempSensor = A0; // Grove - Temperature Sensor connect to A0
int percentage;
//lcd colour
rgb_lcd lcd;
const int colorR = 255;
const int colorG = 255;
const int colorB = 255;
pinMode(buttonPin, INPUT);
Serial.println("Pushing data");
Ethernet.begin(mac); // ethernet card to start connection
delay(1500); //wait for connection
//print connection detail
Serial.print("Arduino IP Address : "); //ip
Serial.println(Ethernet.localIP());
Serial.print("Gateway : ");
Serial.println(Ethernet.gatewayIP());
Serial.print("Subnet Mask : ");
Serial.println(Ethernet.subnetMask());
// read the pushbutton input pin
reading = digitalRead(buttonPin);
// determine if the button is pressed with debounce
if (reading == HIGH && previous == LOW && (millis() - stateTime) > debounce)
Serial.println("Button PUSHED");
if (state == HIGH)
state = LOW;
Serial.println("Status changed to LOW");
lcd.begin(16, 2);
lcd.print("start sending");
delay(2000);
else {
state = HIGH;
Serial.println("Status changed to HIGH");
lcd.begin(16, 2);
lcd.print("stop sending...");
delay(2000);
//off the lcd
const int colorR = 0;
const int colorG = 0;
const int colorB = 0;
lcd.noDisplay();
delay(2000);
lcd.setRGB(colorR, colorG, colorB);
stateTime = millis();
if (state == LOW)
lcd.begin(16, 2);
//ultrasonic
long RangeInCentimeters;
RangeInCentimeters = ultrasonic.MeasureInCentimeters();
percentage = map(RangeInCentimeters, 5, 20, 100, 0);
Serial.println("water level percentage is: ");
Serial.println(percentage);
delay(5000);
//temperature
int a = analogRead(pinTempSensor);
float R = 1023.0/a-1.0;
R = R0*R;
float temperature = 1.0/(log(R/R0)/B+1/298.15)-273.15; // convert to temperature via datasheet
Serial.print("temperature = ");
Serial.println(temperature);
delay(100);
//lcd
lcd.setCursor(0, 0);
lcd.print("waterlevel:");
lcd.print(percentage);
lcd.print("%");
lcd.setCursor(0, 1);
lcd.print("temp:");
lcd.print(temperature );
delay(5000);
//sending data
if (client.connect(server, 80))
Serial.println("-> Connected");
// Make a HTTP request:
client.print("GET http://192.168.10.122/send.php?coolant="percentage"&temperature=" temperature"&co=1&tp=1"); //change based on the server ip
client.println( " HTTP/1.1");
client.print( "Host: " );
client.println( "Connection: close" );
client.println();
client.println();
client.stop();
delay(5000); //every 5 second send one reading
// update previous button state reading
previous = reading;
how do i pass in variable in get request ?
