Arduino GET request parsing large data
Hello,
I am trying to parse hexadecimal values that I receive from a web server after converting an image to a 1 bit BMP image then converting that BMP image to hexadecimal values. This data is received by an Arduino nano IoT 33 via HTTP GET request. This data is basically used to update an eInk display that is attached to the Arduino. The goal is to update the display wirelessly with any image that I want. I am successfully able to send the data to my Arduino however, due to the size of the received data it takes a lot of time to parse this data. The Content-Length of the received data on average is 80540.
I have tried the code mentioned in the following discussion, however, the sheer size of the data makes the process slow to a point where the Arduino just doesn't do anything and my IDE crashes.
https://forum.arduino.cc/index.php?topic=49357.0
https://forum.arduino.cc/index.php?topic=281897.0
I have attached a screenshot below which shows some parts of the data I receive.
Is there any way or any library that I can use to parse this data and save it into an array that can then be used to update the eInk display? A response will be appreciated.
Please post YOUR code
You'r not trying to cram 80,540 bytes of data into 2,000 bytes of RAM are you?
-jimlee
Here's my code for making API call
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
/////// Wifi Settings ///////
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;            // your network key Index number (needed only for WEP)
String readString;
int status = WL_IDLE_STATUS;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128);  // numeric IP for Google (no DNS)
char server[] = "nameoftheserver";
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiSSLClient client;
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to WiFi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  Serial.println("Connected to wifi");
  printWiFiStatus();
  Serial.println("\nStarting connection to server...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 443)) {
    Serial.println("connected to server");
    // Make a HTTP request:
    client.println("GET /API HTTP/1.1");
    client.println("Host: nameofthehost");
    client.println("Connection: close");
    client.println();
  // if there are incoming bytes available
  // from the server, read them and print them:
  while (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting from server.");
    client.stop();
    // do nothing forevermore:
    while (true);
//void saveData(){
//  while (client.available()) {
//    char c = client.read();
//      readString += c;
//  Serial.print(readString);
void printWiFiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
The below seems unusual if something is to keep running.
    while (true);
